Discuss
gas dryer will not heat
 in
Dryer Repair
I need of assistance: My gas dryer operates normally but will not heat. I have replaced the thermostat but this
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » gas dryer will not heat
  #1 (permalink)
Old 09-11-2007, 05:18 PM
retcop320 retcop320 is offline
Junior Member
retcop320 is on a distinguished road
Question gas dryer will not heat
Model Number: LGN2000LW0   Brand: Whirlpool   Age: 1 - 5 years
I need of assistance: My gas dryer operates normally but will not heat. I have replaced the thermostat but this dos not seem to be the problem. Please Help !!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-11-2007, 06:41 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Which thermostat and for what reason?
Open this diagram. Remove #39 plug, start the dryer on TIMED DRY and look through the hole. Give it about 20 seconds, does the igniter glow?
If it does, replace the coils (see below). If it does not, could be a bad flame sensor, burnt igniter, or bad thermal fuse. All can be checked with an ohmmeter for continuity.
- Replacement gas valve coils
- Replacement igniter
- Replacement flame sensor
- Replacement thermal fuse
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No Dryer Heat Warren Dryer Repair 26 11-30-2008 02:06 PM
Gas Dryer no Heat KrazyK55 Dryer Repair 6 01-15-2008 02:22 PM
Dryer will run but not heat allansc Dryer Repair 12 12-28-2007 07:10 PM
Dryer will not heat Michael Collins Dryer Repair 2 09-10-2007 11:44 PM
Dryer won't heat dwh Dryer Repair 1 07-30-2007 06:35 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
