Discuss
Whirpool heating element replaced. dryer not working at all
 in
Dryer Repair
Dryer stopped producing heat. Pulled out heating element from your company. Installed new heating element and was still blowing cold
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirpool heating element replaced. dryer not working at all
  #1 (permalink)
Old 06-19-2010, 04:38 PM
Junior Member
azbabeliz is on a distinguished road
Default Whirpool heating element replaced. dryer not working at all
Model Number: LER5636pq0   Brand: Whirlpool   Age: 1 - 5 years
Dryer stopped producing heat. Pulled out heating element from your company. Installed new heating element and was still blowing cold air. Stopped to look for info on manuels for whirpool dryer on different sites. No luck. I then went back to work on dryer and now dryer wont even start. Was told by a friend that needed to reset relay. read that you couldnt reset.
Please tell me how to get dryer working properly after install of new heating element purchased by your company please.
Ads By Google
Related Models
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
Whirlpool LER6634BN1
Whirlpool LER6634BN2
Whirlpool LER6634BQ0
Whirlpool LER6634BQ1
Whirlpool LER6634BQ2
Whirlpool LER6634BW0
Whirlpool LER6634BW1
Whirlpool LER6634BW2
Whirlpool LER6634DQ0
Whirlpool LER6634DQ1
Whirlpool LER6634DW0
Whirlpool LER6634DW1
Whirlpool LER6634DZ0
Whirlpool LER6634DZ1
Whirlpool LER6636PW0 29" Electric Dryer
Whirlpool LER6636PW1 29" Electric Dryer
Whirlpool LER6638DQ0
Whirlpool LER6638DQ1
Whirlpool LER6638DW0
Whirlpool LER6638DW1
Whirlpool LER6638DZ0
Whirlpool LER6638DZ1
Whirlpool LER6644DQ0
Whirlpool LER6644DQ1
Whirlpool LER6644DZ0
Whirlpool LER6644DZ1
Whirlpool LER6646BN0
Whirlpool LER6646BN1
Whirlpool LER6646BN2
Whirlpool LER6646BW0
Whirlpool LER6646BW1
Whirlpool LER6646BW2
Whirlpool LER6646DN1
Whirlpool LER6646DW1
Whirlpool LER6646PW0 29" Electric Dryer
Whirlpool LER6646PW1 29" Electric Dryer
Whirlpool LER6848AN0
Whirlpool LER6848AN1
Whirlpool LER6848AN2
Whirlpool LER6848AQ2
Whirlpool LER6848AW0
Whirlpool LER6848AW1
Whirlpool LER6848AW2
Whirlpool LER6848AZ2
Whirlpool LER7620KQ0
Whirlpool LER7620KQ1
Whirlpool LER7620KT0
Whirlpool LER7620KT1
Whirlpool LER7620LG0
Whirlpool LER7620LG1 29"electric Dryer
Whirlpool LER7620LQ0
Whirlpool LER7620LW0
Whirlpool LER7620LW1 29"electric Dryer
Whirlpool LER7646AN0
Whirlpool LER7646AN1
Whirlpool LER7646AN2
Whirlpool LER7646AQ0
Whirlpool LER7646AQ1
Whirlpool LER7646AQ2
Whirlpool LER7646AW0
Whirlpool LER7646AW1
Whirlpool LER7646AW2
Whirlpool LER7646AZ0
Whirlpool LER7646AZ1
Whirlpool LER7646AZ2
Whirlpool LER7646DQ0
Whirlpool LER7646DQ1
  #2 (permalink)
Old 06-20-2010, 05:21 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL LER5636PQ0 29"electric Dryer | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/w...%208528187.pdf
Note: I do not work for AppliancePartsPros so if the below advice is no good blame me not them.
How did you know that the heater was blown? Did you measure it with a meter? Was the heating coil broken? Or did you just think that it was the most likely cause?
Could not find a manual but did get the wiring diagram.
You must have messed something up or forgot to reconnect something. The most likely would be the door switch.
You will notice that the motor and the heater circuits are pretty well separate in the unit.
The heater runs on 240 (L1 to L2)
The motor runs on 120 (L1 to Neutral)
I have no idea what your friend was referring to, never heard of a reset relay on a dryer.
You will have to do some trouble shooting a meter will be very helpful here.
First check that the unit is getting the correct power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirpool heating element egarcia528 Dryer Repair 1 04-13-2010 05:15 PM
Replaced upper broil element, lower bake element. Elements still not working bumdout Oven Repair (including Ranges and Cooktops) 1 11-25-2009 02:49 PM
Thermador dual fuel bake/heating element replaced, still not working socalmat Oven Repair (including Ranges and Cooktops) 1 10-28-2009 01:03 PM
Replaced heating element now heating element nor broil element work, all else does rontetley Oven Repair (including Ranges and Cooktops) 1 10-26-2009 01:30 PM
dryer won't start, just replaced heating element Mary T Dryer Repair 1 04-25-2009 12:23 PM
