| » Dryer starts eratically and sometimes stops mid-cycle |
Model Number: 66722 Brand: Kenmore Age: More than 10 years
I have a dryer that has begun to act up. It often doesn't start or requires holding down the start button a few seconds until the motor really engages. Sometimes the motor doesn't engage and it won't respond to the start button at all. Then, after a few minutes, if I come back and try again, it starts. I thought it was a bad starter, but now additionally, when I do finally get it to start, it sometimes quits in the middle of a timed cycle. The timer checks out fine. Could it be overheating? Could the thermostat and the starter have gone up at the same time?
Your model number is short several digits.
Kenmore numbers are usually 3 digits. then 7 or 8 digits. Kenmore does not make any thing and the first 3 digits tell us who actually made the unit. This gives us a better chance at guessing about the tech info for the unit. Could it be overheating? My guess would be that you had/have a motor problem. This then gave you a low air flow through the unit and it has now blown the motor's thermal fuse (usually mounted on the blower assembly along with the cycling thermostat. Could the thermostat and the starter have gone up at the same time? Doubtful but anything is possible.
__________________
| Display Modes | |
| Kenmore dryer starts to heat, makes odd cycle noise and stops heating 2 minutes in | pitcher09 | Dryer Repair | 0 | 08-21-2009 04:46 PM |
| dryer starts than stops | douglasrunion | Dryer Repair | 1 | 03-11-2009 11:51 AM |
| Washer starts and stops during wash cycle | ballardg | Washer Repair | 1 | 02-27-2009 04:28 PM |
| Dryer stops and starts during entire drying cycle, is this normal? | loric228 | Dryer Repair | 2 | 01-05-2009 09:57 AM |
| maytag dishwasher stops cycle starts clicking | rainbow | Dishwasher Repair | 6 | 04-08-2008 08:20 PM |
