Discuss
Heating Element Problem (No Heat)
 in
Dryer Repair
The problem with my dryer is that the heating element will starting working as soon as I turn it on,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Heating Element Problem (No Heat)
  #1 (permalink)
Old 07-22-2008, 04:18 PM
Unknown Unknown is offline
Junior Member
Unknown is on a distinguished road
Default Heating Element Problem (No Heat)
Model Number: JDE2000WC   Brand: Jenn-Air   Age: 5 - 10 years
The problem with my dryer is that the heating element will starting working as soon as I turn it on, but it will turn off a few seconds later, and the machine still keeps running. I already replaced the thermostat near the fan., and it still has the same problem. I don't know what else to do.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-22-2008, 04:39 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
check to see if the exhaust venting at rear of dryer to outside is clean, there shoud be lots of airflow to out side when dryer is running,if not there is a blockage or venting is crushed behind dryer, sometimes birds nest in outside vent
__________________
  #3 (permalink)
Old 07-23-2008, 09:48 AM
Junior Member
Default
Alright, it worked thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Problem reconnecting wire to heat element Loriabrass Dishwasher Repair 1 05-28-2008 03:01 PM
Kitchenaid Heating Element new control board problem clutchless Dishwasher Repair 0 04-28-2008 10:03 AM
Element won't heat up (20ohms on element and 120volts to the element)? puddlejumper123 Oven Repair (including Ranges and Cooktops) 0 04-22-2008 08:49 PM
heating element Single Mom Dryer Repair 1 03-07-2008 05:35 PM
heating element won't heat up mark80 Oven Repair (including Ranges and Cooktops) 1 10-12-2007 03:31 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
