Discuss
Whirlpool/Estate gas dryer drum not turning
 in
Dryer Repair
Hello, The drum on this gas dryer stopped turning. Tried again a few hours later & it worked, then after
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool/Estate gas dryer drum not turning
  #1 (permalink)
Old 06-16-2010, 05:10 PM
Junior Member
dagums is on a distinguished road
Default Whirlpool/Estate gas dryer drum not turning
Model Number: TGDL-680ANO   Brand: Estate   Age: 5 - 10 years
Hello,
The drum on this gas dryer stopped turning. Tried again a few hours later & it worked, then after 4 hrs stopped working again & wouldn't turn any more. When pushing the start button there is a buzzing sound. After doing research I 1st replaced the belt but the drum still wouldn't turn.
I then unplugged the dryer from the wall & disconnected the belt from the idler & tried to turn the motor by hand. It wouldn't turn at all. Using a wrench it will turn. Then I plugged the dryer back into the outlet & had someone push the start button while I watched the motor. The motor would turn but slowly & quickly there was smell of something electrical burning. We stopped right away.
From what I can determine I think the motor is bad & needs replacement. Am I correct or is there any other possible cause?
Thanks in advance for your help.
Bill
Ads By Google
Related Models
Whirlpool TGDL200AN0
Whirlpool TGDL200AW0 Residential Dryer
Whirlpool TGDL200BW0 GAS DRYER
Whirlpool TGDL200WW0 Residential Dryer
Whirlpool TGDL400AW0 Residential Dryer
Whirlpool TGDL400BW0 GAS DRYER
Whirlpool TGDL400BW2 GAS DRYER
Whirlpool TGDL400WW0 Residential Dryer
Whirlpool TGDL400WW1 Residential Dryer
Whirlpool TGDL600WN0
Whirlpool TGDL600WW0 Residential Dryer
Whirlpool TGDL640AW0 Residential Dryer
Whirlpool TGDL640BW0 GAS DRYER
Whirlpool TGDL640BW1 GAS DRYER
Whirlpool TGDL640BW2 GAS DRYER
Whirlpool TGDL640DQ0 GAS DRYER
Whirlpool TGDL640DQ1 GAS DRYER
Whirlpool TGDL660WN0
Whirlpool TGDL660WW0 Residential Dryer
Whirlpool TGDL680AW0 Residential Dryer
 TGDS680BN0 GAS DRYER
 TGDS680BN1 GAS DRYER
 TGDS680BN2 GAS DRYER
 TGDS680BQ1 GAS DRYER
 TGDS680BQ2 GAS DRYER
 TGDS680BW0 GAS DRYER
 TGDS680BW1 GAS DRYER
 TGDS680BW2 GAS DRYER
 TGDS680DQ0 DRYERS
 TGDS680DQ1 GAS DRYER
 TGDS680EQ0 GAS DRYER
 TGDS680EQ1 DRYERS
 TGDS680EQ2 GAS DRYER
 TGDS680EQ3 GAS DRYER
 TGDS740JQ0 DRYER
 TGDS740JQ1 DRYER
 TGDS740JQ2 29"GAS DRYER
 TGDS740PQ0 29" GAS DRYER
 TGDS740PQ1 29"GAS DRYER
 TGDS780JQ0 GAS DRYER
 TGDS780JQ1 RESIDENTIAL DRYER
 TGDS840JQ0 GAS DRYER
 TGDS840JQ1 GAS DRYER
 TGDS840JQ2 29"GAS DRYER
 TGDS840PQ0 29" GAS DRYER
 TGDS840PQ1 29"GAS DRYER
 TGDX540RQ0 29" GAS DRYER
 TGDX540RQ1 29" Gas Dryer
 TGDX640EQ0 DRYER
 TGDX640EQ1 DRYER
 TGDX640EQ2 DRYER
 TGDX640EQ3 DRYER
 TGDX640JQ0 DRYER
 TGDX640JQ1 DRYER
 TGDX640JQ2 DRYER
 TGDX640JQ3 29"GAS DRYER
 TGDX640PQ0 29" GAS DRYER
 TGDX640PQ1 29"GAS DRYER
Tappan TGF303AWA Tappan/gas Range
Tappan TGF303BWA Tappan/gas Range
Tappan TGF303BWB Tappan/gas Range
Tappan TGF303BWC Tappan/gas Range
Frigidaire TGF303BWD Tappan/range
Tappan TGF303BWE Tappan/range
Tappan TGF303BWF GAS RANGE
Tappan TGF303BWG GAS RANGE
Tappan TGF316GSA GAS RANGE
Tappan TGF316GSB GAS RANGE
Tappan TGF316GSC GAS RANGE
Tappan TGF316GSD GAS RANGE
Tappan TGF316GSF GAS RANGE
Tappan TGF317AUA Tappan/range
Tappan TGF317AUB Tappan/gas Range
Tappan TGF317AWA Tappan/range
Tappan TGF317AWB Tappan/gas Range
Tappan TGF317BUA Tappan/gas Range
Tappan TGF317BUB Tappan/gas Range
Tappan TGF317BUC Tappan/gas Range
Tappan TGF317BWA Tappan/gas Range
Tappan TGF317BWB Tappan/gas Range
Tappan TGF317BWC Tappan/gas Range
Tappan TGF317DUA Tappan/gas Range
Tappan TGF317DUB Tappan/gas Range
Tappan TGF317DUC Tappan/range
Tappan TGF317DWB Tappan/gas Range
Tappan TGF317DWC Tappan/range
Tappan TGF317DWD Tappan/range
Tappan TGF317DWE Tappan/range
Tappan TGF317DWF GAS RANGE
Tappan TGF317ESA Tappan/range
Tappan TGF317ESB Tappan/range
Tappan TGF317ESC Tappan/range
Tappan TGF317ESD Tappan/range
Tappan TGF317ESE GAS RANGE
Tappan TGF317ESF TAPPAN/RANGE
Tappan TGF320DUA Tappan/gas Range
Tappan TGF320DWA Tappan/gas Range
Tappan TGF320DWB Tappan/range
Tappan TGF320DWC Tappan/range
Tappan TGF324BHDD Tappan/gas Range
Frigidaire TGF324BHWA
Frigidaire TGF324BHWB
Tappan TGF324BHWC Tappan/range
Tappan TGF324BHWD Tappan/gas Range
Tappan TGF324BHWE Tappan/gas Range
Tappan TGF324WHSA GAS RANGE
Tappan TGF324WHSB GAS RANGE
Tappan TGF324WHSC GAS RANGE
Tappan TGF324WHSD Tappan/gas Range
Tappan TGF326WHSD Tappan/gas Range
Tappan TGF326WHSE Tappan/gas Range
Tappan TGF326WHTD Tappan/gas Range
Tappan TGF326WHTE Tappan/gas Range
Tappan TGF328GSA GAS RANGE
Tappan TGF328GSB GAS RANGE
Tappan TGF328GSC GAS RANGE
Tappan TGF328GSD GAS RANGE
Tappan TGF328GSE GAS RANGE
Tappan TGF328GSG GAS RANGE
Tappan TGF328GSH GAS RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer drum thumps and squeeks when turning megajolt Dryer Repair 1 02-06-2010 06:39 PM
Dryer drum not turning wajeemom Dryer Repair 1 08-18-2009 04:37 PM
Dryer Drum Isnt turning c2heinen Dryer Repair 22 03-19-2009 11:22 AM
Gas Dryer still blowing heat - drum not turning cathylyons Dryer Repair 2 09-29-2008 12:56 PM
Maytag Dryer: Drum Not Turning miatahowie Dryer Repair 2 07-26-2007 07:18 AM
