Discuss
Dryer will spin and no heat
 in
Dryer Repair
My gas dryer will spins but will not heat all started after the lint trap got clogged,i dried a
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer will spin and no heat
  #1 (permalink)
Old 07-21-2008, 04:51 PM
dlg dlg is offline
Junior Member
dlg is on a distinguished road
Default Dryer will spin and no heat
Brand: -brand-   Age: 1 - 5 years
My gas dryer will spins but will not heat all started after the lint trap got clogged,i dried a few loads of cotton rugs and didn't empty the trap...lol now it just spins and will not heat.i cleaned out the trap and took the duct off and everything is clear Tested the thermal fuse and its good,the thermostat internal bias shows continuity on one set of prongs but the other set it does not. should it show continuity on both? "it has 4 prongs" the igniter glows but then it couts off the dryer is only 2 years old.its an inglis igs5000rq0
thanks ,don
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-22-2008, 03:17 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Assuming the gas supply to the dryer is open, the first thing I would do in such situation is replace the gas valve coils.
- The part number for the gas valve coil kit is AP3094251
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 07-22-2008, 03:41 PM
dlg dlg is offline
Junior Member
Default
i ordered the set of coils in earlier today. because everything i tested had continuity so i assumed that was the problem...thanks, i check back when i get them in.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 04:50 PM
Dryer won't heat Motomike228 Dryer Repair 1 05-29-2008 04:33 AM
gas dryer does not heat jlrskymaster Dryer Repair 1 03-14-2008 04:46 PM
No Heat dryer chaionsaw Dryer Repair 3 12-22-2007 03:37 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
