Discuss
Whirlpool Gas Dryer. Heats but will not shut off if on auto dry miser setting
 in
Dryer Repair
My gas dryer heats up fine and works correctly on the timed settings. But it will not turn off and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Gas Dryer. Heats but will not shut off if on auto dry miser setting
  #1 (permalink)
Old 06-11-2010, 09:04 AM
Junior Member
tornado26 is on a distinguished road
Default Whirlpool Gas Dryer. Heats but will not shut off if on auto dry miser setting
Model Number: LGR7646EQ0   Brand: Whirlpool   Age: More than 10 years
My gas dryer heats up fine and works correctly on the timed settings. But it will not turn off and the dial does not advance when using the automatic dry miser setting. It also does not heat up or dry the clothes when that setting is being used. I cleaned out the interior cabinet about a month ago when I replaced the two wheels for the drum. Any idea?
Related Models
Whirlpool LGR7646EQ0 DRYER
Whirlpool LGR7646EQ1 DRYERS
Whirlpool LGR7646EQ2 GAS DRYER
Whirlpool LGR7646EQ3 GAS DRYER
Whirlpool LGR7646EZ0 DRYER
Whirlpool LGR7646EZ1 DRYERS
Whirlpool LGR7646EZ2 GAS DRYER
Whirlpool LGR7646EZ3 GAS DRYER
Whirlpool LGR7646JQ0 GAS DRYER
Whirlpool LGR7646JQ1 RESIDENTIAL DRYER
Whirlpool LGR7646JT0 GAS DRYER
Whirlpool LGR7646JT1 RESIDENTIAL DRYER
Whirlpool LGR7648KQ0 RESIDENTIAL DRYER
Whirlpool LGR7648KQ1 RESIDENTIAL DRYER
Whirlpool LGR7648KQ2 29"GAS DRYER
Whirlpool LGR7648KT0 RESIDENTIAL DRYER
Whirlpool LGR7648KT1 RESIDENTIAL DRYER
Whirlpool LGR7648KT2 29"GAS DRYER
Whirlpool LGR7648PQ0 29" GAS DRYER
Whirlpool LGR7648PQ1 29" GAS DRYER
Whirlpool LGR7648PT0 29" GAS DRYER
Whirlpool LGR7648PT1 29" GAS DRYER
Whirlpool LGR7848DQ0 GAS DRYER
Whirlpool LGR7848DQ1 GAS DRYER
Whirlpool LGR7848DZ0 GAS DRYER
Whirlpool LGR7848DZ1 GAS DRYER
Whirlpool LGR7858AN1 GAS DRYER
Whirlpool LGR7858AN2 GAS DRYER
Whirlpool LGR7858AW0 Residential Dryer
Whirlpool LGR7858AW1 GAS DRYER
Whirlpool LGR7858AW2 GAS DRYER
Whirlpool LGR8620PG0 29"GAS DRYER
Whirlpool LGR8620PG1 29"GAS DRYER
Whirlpool LGR8620PW0 29"GAS DRYER
Whirlpool LGR8620PW1 29"GAS DRYER
Whirlpool LGR8646LG0 RESIDENTIAL DRYER
Whirlpool LGR8648LG1 29"GAS DRYER
Whirlpool LGR8648LQ0 RESIDENTIAL DRYER
Whirlpool LGR8648LW0 RESIDENTIAL DRYER
Whirlpool LGR8648LW1 29"GAS DRYER
Whirlpool LGR8648PG0 29"GAS DRYER
Whirlpool LGR8648PG1 29" Gas Dryer
Whirlpool LGR8648PQ0 29" GAS DRYER
Whirlpool LGR8648PQ1 29" Gas Dryer
Whirlpool LGR8648PW0 29"GAS DRYER
Whirlpool LGR8648PW1 29" Gas Dryer
Whirlpool LGR8857EQ0 GAS DRYER
Whirlpool LGR8857EQ1 DRYERS
Whirlpool LGR8857EQ2 GAS DRYER
Whirlpool LGR8857EQ3 GAS DRYER
Whirlpool LGR8857EZ0 GAS DRYER
Whirlpool LGR8857EZ1 DRYERS
Whirlpool LGR8857EZ2 GAS DRYER
Whirlpool LGR8857EZ3 GAS DRYER
Whirlpool LGR8858DQ0 GAS DRYER
Whirlpool LGR8858DQ1 GAS DRYER
Whirlpool LGR8858DZ0 GAS DRYER
Whirlpool LGR8858DZ1 GAS DRYER
Whirlpool LGR8858EQ0 GAS DRYER
Whirlpool LGR8858EQ1 DRYERS
Whirlpool LGR8858EQ2 GAS DRYER
Whirlpool LGR8858EQ3 GAS DRYER
Whirlpool LGR8858EZ0 GAS DRYER
Whirlpool LGR8858EZ1 DRYERS
Whirlpool LGR8858EZ2 GAS DRYER
Whirlpool LGR8858EZ3 GAS DRYER
Amana LGS10AW WASHER-TOP LOADING
Amana LGS19AW DRYER- GAS
Amana LGS33AW DRYER- GAS
Amana LGS34AW WASHER-TOP LOADING
Frigidaire LGS389FEA Frigidaire/gas Range
Whirlpool LGT5434AQ0 Residential Dryer
Whirlpool LGT5434AW0 Residential Dryer
Whirlpool LGT5436AW0 Residential Dryer
Whirlpool LGT5624BN0 GAS DRYER
Whirlpool LGT5624BN1 GAS DRYER
Whirlpool LGT5624BN2 GAS DRYER
Whirlpool LGT5624BQ0 GAS DRYER
Whirlpool LGT5624BQ1 GAS DRYER
Whirlpool LGT5624BQ2 GAS DRYER
Whirlpool LGT5624BW0 GAS DRYER
Whirlpool LGT5624BW1 GAS DRYER
Whirlpool LGT5624BW2 GAS DRYER
Whirlpool LGT5624DQ0 GAS DRYER
Whirlpool LGT5624DQ1 GAS DRYER
Whirlpool LGT6634AN1 DRYER
Whirlpool LGT6634AN2 GAS DRYER
Whirlpool LGT6634AQ0 GAS DRYER
Whirlpool LGT6634AQ1 GAS DRYER
Whirlpool LGT6634AQ2 GAS DRYER
Whirlpool LGT6634AW0 Residential Dryer
Whirlpool LGT6634AW1 DRYER
Whirlpool LGT6634AW2 GAS DRYER
Whirlpool LGT6634DQ0 GAS DRYER
Whirlpool LGT6634DQ1 GAS DRYER
Whirlpool LGT6634DZ0 GAS DRYER
Whirlpool LGT6634DZ1 GAS DRYER
Whirlpool LGT6638AN1 GAS DRYER
Whirlpool LGT6638AN2 GAS DRYER
Whirlpool LGT6638AQ2 GAS DRYER
Whirlpool LGT6638AW0 Residential Dryer
Whirlpool LGT6638AW1 GAS DRYER
Whirlpool LGT6638AW2 GAS DRYER
Whirlpool LGT6638DQ0 GAS DRYER
Whirlpool LGT6638DQ1 GAS DRYER
Whirlpool LGT6638DZ0 GAS DRYER
Whirlpool LGT6638DZ1 GAS DRYER
Whirlpool LGT7646AQ0 Residential Dryer
Whirlpool LGT7646AQ2 GAS DRYER
Whirlpool LGT7646AW0 Residential Dryer
Whirlpool LGT7646AZ2 GAS DRYER
Whirlpool LGT7646DQ0 GAS DRYER
Whirlpool LGT7646DQ1 GAS DRYER
Whirlpool LGT7646DZ0 GAS DRYER
Whirlpool LGT7646DZ1 GAS DRYER
Whirlpool LGT7646EQ0 GAS DRYER
Whirlpool LGT7646EQ1 DRYERS
Whirlpool LGT7646EQ2 GAS DRYER
Whirlpool LGT7646EQ3 GAS DRYER
Whirlpool LGT7646EZ0 GAS DRYER
  #2 (permalink)
Old 06-12-2010, 08:39 AM
Junior Member
lcjacks is on a distinguished road
Default Dryer will not shut off
Maytag dryer will not shut off. Purchased a new timer and it still will not shut off. What to do next? Can I receive a refund for the new timer that was purchased this week?
  #3 (permalink)
Old 12-23-2011, 01:01 PM
Junior Member
broken down again is on a distinguished road
Default Did you get an answer?
  #4 (permalink)
Old 12-30-2011, 10:37 AM
Junior Member
Wizard9801 is on a distinguished road
Default Amost the same problem
My LGR7646EQ3 heats but doesn't shut off until long after the clothes are dry. The vent is not clogged, both the Dryer cycling thermostat and Hi-limt thermostat have continuity.
  #5 (permalink)
Old 01-01-2012, 09:15 AM
Junior Member
Default Whirlpool Automatic Dry-miser setting
I have the same problem that you did. Dryer heats but does not shut off when clothes are dry. Evenually it shuts off but runs far too long. Did you find what your problem was?
  #6 (permalink)
Old 01-01-2012, 09:43 AM
Junior Member
Danplus is on a distinguished road
Default
Not yet but if its the selection knob, that alone cost about 113.00 for mine. That]s more than half of what I paid for the dryer. I'm still researching. By the way, I have an electric dryer not a gas like I posted earlier. But if you want an idea of what some of the parts cost, go to their convenient main page and enter your model number and it has a lot of info. I will post whatever I find out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
auto sensing setting won't shut off chuckkapl Dryer Repair 1 04-22-2010 04:40 AM
Whirlpool Dryer will not dry on auto setting Dave H. Dryer Repair 0 04-21-2010 04:34 PM
auto sensing setting won't shut off chuckkapl Dishwasher Repair 0 04-21-2010 01:45 PM
Dryer heats in auto but wont shut off CSH12H Dryer Repair 1 10-16-2009 11:51 AM
whirlpool dryer wont start in dry miser mode tequilla Dryer Repair 3 06-23-2008 07:03 PM
