Discuss
Amana Dryer will not shut off
 in
Dryer Repair
I have an Amana dryer that is not shutting off when using the electronic dry cycle. It works fine when
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Amana Dryer will not shut off
  #1 (permalink)
Old 06-08-2010, 06:04 PM
Junior Member
kruczeric is on a distinguished road
Question Amana Dryer will not shut off
Model Number: ALE866SBW   Brand: Amana   Age: 1 - 5 years
I have an Amana dryer that is not shutting off when using the electronic dry cycle. It works fine when using the timer, though. Any thoughts on this?
Related Models
Amana ALE866SBW DRYER- ELE
Amana ALE866SCW DRYER- ELE
Amana ALE868QAW DRYER- ELE
Amana ALE868QCW WASHER-TOP LOADING
Amana ALE956EAC DRYER- ELE
Amana ALE956EAW DRYER- ELE
Whirlpool ALF12420 Air-conditioner/heat pump
Whirlpool ALF15040 Air-conditioner/heat pump
Whirlpool ALF20040 Air-conditioner/heat pump
Whirlpool ALF21040 Air-conditioner/heat pump
Whirlpool ALF24040 Air-conditioner/heat pump
Whirlpool ALFH0820 Air-conditioner/heat pump
Amana ALG120RAW DRYER- GAS
Amana ALG230RAW DRYER- GAS
Amana ALG230RCW DRYER- GAS
Amana ALG331RAC DRYER- GAS
Amana ALG331RAW DRYER- GAS
Amana ALG331RMC DRYER- GAS
Amana ALG331RMW DRYER- GAS
Amana ALG443RAC DRYER- GAS
Amana ALG443RAW DRYER- GAS
Amana ALG443RCW DRYER- GAS
Amana ALG565SAC DRYER- GAS
Amana ALG565SAW DRYER- GAS
Amana ALG643RAC DRYER- GAS
Amana ALG643RAW DRYER- GAS
Amana ALG643RBC DRYER- GAS
Amana ALG643RBW DRYER- GAS
Amana ALG643RMC WASHER-TOP LOADING
Amana ALG643RMC DRYER- GAS
Amana ALG643RMC1 WASHER-TOP LOADING
Amana ALG643RMW WASHER-TOP LOADING
Amana ALG643RMW DRYER- GAS
Amana ALG643RMW1 WASHER-TOP LOADING
Amana ALG665SAC DRYER- GAS
Amana ALG665SAW DRYER- GAS
Amana ALG866SAC DRYER- GAS
Amana ALG866SAW DRYER- GAS
Amana ALG866SBC DRYER- GAS
Amana ALG866SBW DRYER- GAS
Amana ALG866SCW DRYER- GAS
Amana ALG868QAW DRYER- GAS
Amana ALG868QCW WASHER-TOP LOADING
Amana ALG956EAC DRYER- GAS
Amana ALG956EAW DRYER- GAS
Whirlpool ALJ00520 Air-conditioner/heat pump
Whirlpool ALJ07520 Air-conditioner/heat pump
Whirlpool ALJ10020 Air-conditioner/heat pump
Whirlpool ALJ12020 Air-conditioner/heat pump
Whirlpool ALJ18040 Air-conditioner/heat pump
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
Admiral ALR1100AJQ RANGE- F/S STD GAS
Admiral ALR1100AJW RANGE- F/S STD GAS
Admiral ALR1420BDQ RANGE- F/S STD GAS
Admiral ALR1420BDW RANGE- F/S STD GAS
Admiral ALR1450AJW RANGE- F/S STD GAS
Admiral ALR1450BJW RANGE- F/S STD GAS
Admiral ALR5715QDS RANGE- S/C F/S GAS
Admiral ALR5715QDW RANGE- S/C F/S GAS
Amana ALW110RAW WASHER-TOP LOADING
Amana ALW210RAW WASHER-TOP LOADING
Amana ALW210RMC Washer - Top Loading
Amana ALW210RMC WASHER-TOP LOADING
Amana ALW210RMW Washer - Top Loading
Amana ALW210RMW WASHER-TOP LOADING
Admiral ALW221RJW WASHER-TOP LOADING
Amana ALW410DAW WASHER-TOP LOADING
Amana ALW430RAC WASHER-TOP LOADING
Amana ALW430RAW WASHER-TOP LOADING
Amana ALW432RAW WASHER-TOP LOADING
Amana ALW450QAC WASHER-TOP LOADING
Amana ALW450QAW WASHER-TOP LOADING
Amana ALW480DAC WASHER-TOP LOADING
Amana ALW480DAW WASHER-TOP LOADING
Amana ALW540RAC WASHER-TOP LOADING
Amana ALW540RAW WASHER-TOP LOADING
Amana ALW540RMC Washer - Top Loading
Amana ALW540RMC WASHER-TOP LOADING
  #2 (permalink)
Old 06-09-2010, 04:06 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for AMANA ALE866SBW Dryer - Ele | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/maytag...T3220008R2.pdf
Here is a manual
http://www.servicematters.com/maytag...S3200007R0.pdf
Could be a number of things but at the the top of the list would be a dirty moisture sensor Item 18 in Section 4. Clean them with either water or isopropyl alcohol or electronics contact cleaner. Be sure they are dry betore testing. Also if using a solvent leave the door open for sometime as you want to let the vapors clear.
FYI
When there is moisture between the parallel metal strips, it provides a current path for low voltage. The board then senses this and does not advance the timer. When there is no moisture then no current and the timer advances. Anything that provides a current path between the strips will make the unit think the clothes are still wet and will continue to try and dry them.
__________________
  #3 (permalink)
Old 06-09-2010, 08:03 PM
Junior Member
Default
ok, I tried testing the sensor by putting a piece of metal across the sensor and I started the automatic normal cycle, it sounded the beeper 3 times to indicate self-test which is normal, then removed the metal piece after a few minutes, and it worked fine. This has been an intermittent problem, though, when doing the laundry, sometimes it works fine and sometimes it never shuts off.
  #4 (permalink)
Old 06-10-2010, 03:40 AM
Senior Expert
APP Volunteer
Default
Intermittent problem is a synonym for tech's nightmare as every time you try to repair it the unit will run OK.
Here is a bulletin on the moisture control board that may apply
http://www.servicematters.com/maytag.../ASQ-234-B.pdf
Often an intermittent problem is a bad solder joint or connection but in this case that should stop the dryer before the clothes are dry not keep it running.
I would check the connections from the moisture sensor to the board to ensure there is no dust etc. between them.
Check the solder side of the moisture control board for bad solder joints.
Often a cold solder joint will be a duller gray color.
It may have pin holes in it.
When gently wiggling the componen you can see it's leg move on the solder side of the board.t
After that I would replace the moisture sensor board but this is just a guess and I hate doing Plug & Chug repairs.
Keep plugging in new parts till the unit chugs along on it's merry way.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer won't shut off, I replaced timer...still does not shut off. jwd Dryer Repair 0 03-20-2010 04:39 PM
Amana convenience light won't shut off raykatta Microwave Repair 0 03-15-2010 11:15 AM
My dryer timer doesnt shut off the dryer swilson39 Dryer Repair 1 12-13-2009 12:48 PM
Amana electric oven won't shut off Kirkfarley Oven Repair (including Ranges and Cooktops) 1 04-25-2009 01:34 PM
Amana Automatic Shut -Off Problem ed wilson Dryer Repair 3 12-10-2008 04:30 AM
