| » will this pump also pump the drain water out |
Model Number: wd19x59 Brand: GE Age: 5 - 10 years
I have a GE dishwasher GSD4310Y73AA which no longer drains enough water out. I assume the pump went bad. Is WD19X59 "pump dual" the correct part to pump out the drtain water?
Thanks much. Paul Ads By Google Related Models |
Hi Paul,
This pump is a last thing I would think about in such situation. The first thing I would check is the air gap on top of the sink (if there is one). Remove the top cover and the top piece and check the air gap for a clog. Disconnect the drain hose from the air gap, or from the garbage disposer if there is no air gap, put the end of the drain hose in a bucket and run the drain cycle to see if there are any foreign objects inside the hose. Post your findings. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Gene,
I have a flexible hose that goes 32" + above the floor and it is all clear. All the other hoses are clear and the connection to the sink's drain pipe is clear. I also checked all the traps on the bottom inside and they have no garbage in them. Any other thoughts? Thank you very much. Paul |
Paul,
Remove the filter frame (#543 on the break down diagram), unscrew and check the piston & nut assembly (#564 on the break down diagram). The rubber cone should close the center hole when it's in upper position and it should move freely up & down. - The part number for the piston & nut assembly is AP2617344 Gene.
__________________
Hi Paul,
Keep us posted. Gene.
__________________
| Display Modes | |
| bosch shu9925 - drain pump works, won't drain after cycle | mjbarr | Dishwasher Repair | 0 | 10-16-2009 01:11 PM |
| Bosch washer pump issue (already replaced pump!) | wdt | Washer Repair | 0 | 12-02-2008 06:26 AM |
| pump comes on but water will not drain | eric4442 | Dishwasher Repair | 1 | 09-19-2008 01:57 PM |
| sock stuck in water pump... do i need a new pump? | volcompunker82 | Washer Repair | 0 | 03-08-2008 07:20 PM |
| Washer won't drain during spin cycle. Water Pump Belt discovered on floor | sandydjdm | Washer Repair | 1 | 08-14-2007 07:41 PM |
