Discuss
Bosch dishwasher not completing cycle
 in
Dishwasher Repair
Our Bosch dishwasher is 3 years old and is doing strange things. The time showing the length of the cycle
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch dishwasher not completing cycle
  #1 (permalink)
Old 05-29-2010, 12:11 PM
Junior Member
wjweinhardt is on a distinguished road
Smile Bosch dishwasher not completing cycle
Model Number: SHE44c   Brand: Bosch   Age: 1 - 5 years
Our Bosch dishwasher is 3 years old and is doing strange things. The time showing the length of the cycle is irregular and when it reaches the end it stay+6s at 1 min. and keeps running until you push the "cancel drain" buttons. when you open the dishwasher it seems the dry cycle has not run and the dishes are not as clean as they should be. I'd rather not call a serviceman if this is a common problem with a know fix. I'm pretty mechanically inclined and should be able to repair whatever it is. We are a little disappointed to have a problem so soon after owning a Maytag that went problem free for more then 20 years. Any help would be appreciated.
Ads By Google
Related Models
Whirlpool SHF3800W0
Whirlpool SHF3800W1
Whirlpool SHF3801W0
Whirlpool SHF3804W0
Whirlpool SHF3804W2
Whirlpool SHF4500W0
Whirlpool SHF5500W0
Whirlpool SHF5501W0
Whirlpool SHF5504W0
Whirlpool SHF5584P0
Whirlpool SHF5584P1
Whirlpool SHF5584P2
Whirlpool SHF5800W0
Whirlpool SHF5800W1
Whirlpool SHF5801W0
Whirlpool SHF5801W1
Whirlpool SHF5880P0
Whirlpool SHF5884P0
Whirlpool SHF5884P1
Whirlpool SHF5884P2
Whirlpool SHF6000W0
Whirlpool SHF6000W1
Whirlpool SHF6002W0
Whirlpool SHF7800W0
Whirlpool SHF7800W1
Whirlpool SHF7801W0
Whirlpool SHF7804W0
Whirlpool SHF7804W1
Whirlpool SHF7884P0
Whirlpool SHF7884P1
Whirlpool SHF7884P2
Bosch SHI4302 UC/06 -FD8002
Bosch SHI4302 UC/11 -FD8003
Bosch SHI4302 UC/12
Bosch SHI4306 UC/06 -FD8002
Bosch SHI4306 UC/11 -FD8003
Bosch SHI4306 UC/12
Bosch SHI66A05 UC/14 (FD 8211-)
Bosch SHI6802 UC/06
Bosch SHI6802 UC/11
Bosch SHI6802 UC/12
Bosch SHI6805 UC/06
Bosch SHI6805 UC/11
Bosch SHI6805 UC/12
Bosch SHI6806 UC/06
Bosch SHI6806 UC/11
Bosch SHI6806 UC/12
Whirlpool SHU30000
Whirlpool SHU30010
Whirlpool SHU30011
Bosch SHU3002
Whirlpool SHU30040
Whirlpool SHU30041
Bosch SHU3006
Whirlpool SHU30110
Bosch SHU3012
Whirlpool SHU30140
Whirlpool SHU30141
Bosch SHU3016
Bosch SHU3032 UC/06 (FD 7908-8002)
Bosch SHU3032 UC/11 (FD 8002-8003)
Bosch SHU3032 UC/12 (FD 8003-)
Bosch SHU3035 UC/12 (FD 8006-)
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
Bosch SHU3302 UC/11 (FD 8003-8003)
Bosch SHU3302 UC/12 (FD 8003 -)
Bosch SHU3305 UC/06 (FD 7902-8003)
Bosch SHU3305 UC/11 (FD 8003-8003)
Bosch SHU3305 UC/12 (FD 8003 -)
Bosch SHU3306 UC/06 (FD 7902-8003)
Bosch SHU3306 UC/11 (FD 8003-8003)
Bosch SHU3306 UC/12 (FD 8003 -)
Bosch SHU3307 UC/12 (FD 8005 -)
Bosch SHU3322 UC/06
Bosch SHU3322 UC/11
Bosch SHU3322 UC/12
Bosch SHU3322 UC/12 (FD 8003-)
Bosch SHU3326 UC/06
Bosch SHU3326 UC/11
Bosch SHU3326 UC/12
Bosch SHU3326 UC/12 (FD 8003-)
Bosch SHU3336 UC/06
Bosch SHU3336 UC/11
Bosch SHU3336 UC/12
Bosch SHU3336 UC/12 (FD 8003-)
Bosch SHU33A02 UC/14 (FD 8211-)
Bosch SHU33A06 UC/14 (FD 8211-)
Bosch SHU33AC02 UC/14
Bosch SHU33AC06 UC/14
Whirlpool SHU40000
Whirlpool SHU40010
Whirlpool SHU40011
Bosch SHU4002 UC/06
Whirlpool SHU40040
Whirlpool SHU40041
Bosch SHU4006 UC/06
Bosch SHU4016 UC/06
Bosch SHU4022 UC/06
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
  #2 (permalink)
Old 07-22-2010, 05:23 AM
ob1 ob1 is offline
Junior Member
ob1 is on a distinguished road
Default
Hi ya I have the same issue.... did you ever get a fix...
in the passed I use to refill the washer with hot water from a kettle and that seemed to restart the cylcle and allow it to complete. However even this has failed.
so if you reslove can you let me know
  #3 (permalink)
Old 07-22-2010, 05:53 AM
Junior Member
PapofNC1 is on a distinguished road
Default
I had the same problem, and found it to be caused by an open circuit in the heater. Apparently the failure to heat the water causes the system to lengthen the cycle in an attempt to extend the time for heating the water. Since it never gets hot enough, the machine stays at 1 and never completes.
The cause of the open circuit, in my machine was due to overheating of the relay on the control board, which burned up the relay pin. The relay carries the relatively high current of the heater circuit, which heats up the pin and circuitry. This is a poor thermal design, because the board in enclosed in a plastic box, which inhibits the airflow. You either have to jury rig the board to repair the connection, or buy the new control board. I was able to repair the board, and that fixed the timing issues.
If anyone has found a source for the relay, I would like to buy a new relay. I contacted the relay manufacturer, and they told me that the relay has never been sold in the US. The relay in made by Song Chuan. Part number is 899B-1C-F-C-6VDC
  #4 (permalink)
Old 07-23-2010, 02:24 PM
Junior Member
Mike Quattrini is on a distinguished road
Default It's more of a circuit board problem than a relay problem
The connection between the relay and the circuit board doesn't stand up to that much current long term and burns out. I resoldered mine about three years ago and it's still doing fine. The relay shouldn't need replacement. This issue is covered inthe Troubleshooting manual available online, but the burnt connection is pretty easy to find and repair onthe circuit board. Saves buying an expensive part.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile Dishwasher-Not completing cycle john j dobise jr Dishwasher Repair 0 11-16-2009 09:56 AM
Dishwasher stops after completing first cycle buck999 Dishwasher Repair 3 06-18-2009 03:32 PM
whirlpool not completing cycle JOSH MANN Washer Repair 3 03-18-2008 02:00 PM
Another Bosch not completing cycle robink Dishwasher Repair 1 10-16-2007 01:12 PM
Not completing cycle eroocraw Dishwasher Repair 1 08-14-2007 01:10 PM
