Discuss
Dish washer will not spin
 in
Dishwasher Repair
UP till 2 weeks ago my dish washer ran fine.Then the termal fuse went out.So i traced that down casue
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dish washer will not spin
  #1 (permalink)
Old 05-26-2010, 04:43 PM
Junior Member
rednck7736 is on a distinguished road
Default Dish washer will not spin
Model Number: du920pfgb4   Brand: Whirlpool   Age: 5 - 10 years
UP till 2 weeks ago my dish washer ran fine.Then the termal fuse went out.So i traced that down casue it would not even come on.Found it and replace it.All was good till it came to the drain cycle.It will turn one way to was like normal and everything but when it has to turn the other way to drain the water out it just want turn.You can hear it humming and fell it motor vibrator for a second then it stops and does nothing.You can here what sound like a relay in teh door trip.The motor spins freely in both directoins by hand.I kow this cause I tripped the latch swith and turned it on and then let it spry to wash and then let it fill and did it again to watch it try to drain. It runs through all the cycles and once its done the clean light is on.But there is still standing water in the bottom right up to the float switch which cuts the water flow off once the drum is full.I have gone through all the drain lines.theres nothing stuck in bottom.I took all the bottom a part to make sure theirs nothing in it.I am pretty sure it a relay the makes it reserse for it to drain.Just not sure which one it is.
Ads By Google
Related Models
Whirlpool DU920PFGB4
Whirlpool DU920PFGQ0
Whirlpool DU920PFGQ1
Whirlpool DU920PFGQ2
Whirlpool DU920PFGQ3
Whirlpool DU920PFGQ4
Whirlpool DU920PFGT4
Whirlpool DU920PFGZ0
Whirlpool DU920PFGZ1
Whirlpool DU920PFGZ2
Whirlpool DU920PFGZ3
Whirlpool DU920PFGZ4
Whirlpool DU920PWKB0
Whirlpool DU920PWKQ0
Whirlpool DU920PWKS0 Undercounter Dishwasher
Whirlpool DU920PWKT0
Whirlpool DU920QWDB0
Whirlpool DU920QWDB2
Whirlpool DU920QWDB3
Whirlpool DU920QWDB4
Whirlpool DU920QWDB5
Whirlpool DU920QWDB6
Whirlpool DU920QWDQ0
Whirlpool DU920QWDQ2
Whirlpool DU920QWDQ3
Whirlpool DU920QWDQ4
Whirlpool DU920QWDQ5
Whirlpool DU920QWDQ6
Whirlpool DU925QWDB0
Whirlpool DU925QWDB2
Whirlpool DU925QWDB3
Whirlpool DU925QWDB4
Whirlpool DU925QWDB5
Whirlpool DU925QWDB6
Whirlpool DU925QWDQ0
Whirlpool DU925QWDQ2
Whirlpool DU925QWDQ3
Whirlpool DU925QWDQ4
Whirlpool DU925QWDQ5
Whirlpool DU925QWDQ6
Whirlpool DU925SCGB0
Whirlpool DU925SCGB1
Whirlpool DU925SCGB2
Whirlpool DU925SCGB3
Whirlpool DU925SCGQ0
Whirlpool DU925SCGQ1
Whirlpool DU925SCGQ2
Whirlpool DU925SCGQ3
Whirlpool DU925SCGZ1
Whirlpool DU925SCGZ2
Whirlpool DU925SCGZ3
Whirlpool DU927QWDB0
Whirlpool DU927QWDB1
Whirlpool DU927QWDQ0
Whirlpool DU927QWDQ1
Whirlpool DU927QWDZ0
Whirlpool DU927QWDZ1
Whirlpool DU929PFGB0
Whirlpool DU929PFGB1
Whirlpool DU929PFGB2
Whirlpool DU929PFGQ0
Whirlpool DU929PFGQ1
Whirlpool DU929PFGQ2
Whirlpool DU929QWDB0
Whirlpool DU929QWDB1
Whirlpool DU929QWDQ0
Whirlpool DU929QWDQ1
Whirlpool DU930PWKB0
Whirlpool DU930PWKQ0
Whirlpool DU930PWPB0 Undercounter Dishwasher
Whirlpool DU930PWPB1 Undercounter Dishwasher
Whirlpool DU930PWPB2 Undercounter Dishwasher
Whirlpool DU930PWPQ0 Undercounter Dishwasher
Whirlpool DU930PWPQ1 Undercounter Dishwasher
Whirlpool DU930PWPQ2 Undercounter Dishwasher
Whirlpool DU930PWPS0 Undercounter Dishwasher
Whirlpool DU930PWPS1 Undercounter Dishwasher
Whirlpool DU930PWPS2 Undercounter Dishwasher
Whirlpool DU930PWPT0 Undercounter Dishwasher
Whirlpool DU930PWPT1 Undercounter Dishwasher
Whirlpool DU930PWPT2 Undercounter Dishwasher
Whirlpool DU930PWSB0 Undercounter Dishwasher
Whirlpool DU930PWSQ0 Undercounter Dishwasher
Whirlpool DU930PWSS0 Undercounter Dishwasher
Whirlpool DU930PWST0 Undercounter Dishwasher
Whirlpool DU930QWDB0
Whirlpool DU930QWDB2
Whirlpool DU930QWDB3
Whirlpool DU930QWDB4
Whirlpool DU930QWDB5
Whirlpool DU930QWDB6
Whirlpool DU930QWDQ0
Whirlpool DU930QWDQ2
Whirlpool DU930QWDQ3
Whirlpool DU930QWDQ4
Whirlpool DU930QWDQ5
Whirlpool DU930QWDQ6
Whirlpool DU931SCGB0
Whirlpool DU931SCGB1
Whirlpool DU931SCGQ0
Whirlpool DU931SCGQ1
Whirlpool DU935QWDB0
Whirlpool DU935QWDB1
Whirlpool DU935QWDB5
Whirlpool DU935QWDB6
Whirlpool DU935QWDQ0
Whirlpool DU935QWDQ1
Whirlpool DU935QWDQ5
Whirlpool DU935QWDQ6
Whirlpool DU9400XB0
Whirlpool DU9400XB1
Whirlpool DU9400XT0
Whirlpool DU9400XT1
Whirlpool DU9400XT4
Whirlpool DU9400XY0
Whirlpool DU9400XY1
Whirlpool DU9400XY2
Whirlpool DU940PWKB0
Whirlpool DU940PWKB1
Whirlpool DU940PWKQ0
  #2 (permalink)
Old 05-27-2010, 03:31 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL DU920PFGB4 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/w...%208051291.pdf
Since the motor turns easily in both directions and the drains are clear, it sounds like the motor is toast.
You could remove power from the unit and check the drain winding with a meter.
Note: That this is not a definitive test but if the drain winding is open then the motor is toast. If it measures OK the motor may still be toast.
You could then measure the drain winding voltage if you get 120 volts when you should and the motor does not turn, it is toast.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dish washer gsonny50 Washer Repair 1 01-13-2010 03:18 PM
dish washer fj4x4 Dishwasher Repair 4 01-08-2010 06:04 AM
Dish Washer George Madden Dishwasher Repair 1 01-13-2008 10:04 AM
dish washer lsj1402 Dishwasher Repair 5 09-11-2007 04:00 AM
