hrmkr
#1 Posted : Wednesday, July 9, 2008 6:09:25 AM(UTC)
hrmkr
After closing the door and hearing it clicked closed, it will not turn on when you hit the start button. It does have power and the breaker is not tripped. When I press the button for delayed start, the 2 hour light turns on. I can hit cancel to stop it.
I think it may be the timer that is messed up.
Any thoughts??
#2 Posted : Wednesday, July 9, 2008 10:13:33 PM(UTC)
Would it start if you used delayed option?
hrmkr
#3 Posted : Thursday, July 10, 2008 4:20:12 AM(UTC)
hrmkr
Not sure. I will try tonight and post the results.
Thanks for replying
hrmkr
#4 Posted : Thursday, July 10, 2008 6:03:09 PM(UTC)
hrmkr
It did not start. The 2 hour delay light stayed lit and the no heat dry and lock on lights flashed.
#5 Posted : Friday, July 11, 2008 10:41:02 AM(UTC)
Check both door switches.
- The part number for the door switches kit is AP3103581
hrmkr
#6 Posted : Friday, July 11, 2008 12:16:28 PM(UTC)
hrmkr
The door is properly latching when you push it closed. You can hear it click and does not open when you pull on it.
#7 Posted : Friday, July 11, 2008 12:20:58 PM(UTC)
I did not mean "door latch" when I said "door switches".
