I'm having problems with drainage. The machine pumps everything out okay, but it will but not come out of drainge mode. It pumps water in and goes through first wash but then I get a code C1 and then a code C4. I replaced the piston with rubber valve in the back of the machine, but it did not help this time. There are no blockages in hoses. Pump and impeller looks good. Drainage solenoid energizes for just a short time, as it should. Then drain flap will not go back to normal when water stops coming out. It's even hard to force back to normal. Turn the machine off and th edarin valve falls back to normal. Also, when I had the pump out, the drain flap works very easy. There were two rubber flap valves, but they deteriorated and do not seem to be available any more. They are suppose to act as check valves but I don't see where they would have been too effective. Could they be a problem? If they are no longer available, nobody must be putting them back in. Machine is to old to buy an entire pump assembly.
