| » pump motor switching on off on off etc |
Model Number: GU1500XTKT0 Brand: Whirlpool Age: 5 - 10 years
For several weeks dishwasher had loud whining noise when washing. Now it will not wash but will drain. Each time the wash pump attempts to run, it sounds like it is running but then abruptly stops after a few seconds. Then after a few seconds, it trys to run again but stops after a few seconds. This repeats over and over about 10 or 12 times and then the pump stops completely. Although the wash pump is not running, the control panel cycles through and the drain pump will eventually empty the dishwasher. I have completely removed the washer pump and hot wired it to see that it does exactly the same thing as a standalone motor. The shaft turns then stops then turns then stops every few seconds. The shaft turns freely with no grinding noise. During the few seconds of start stop start stop the motor gets extremely hot and has an electrical smell. I believe I need a whole new pump motor. The original pump motor part number is 8268408. Please advise. Thanks, Charles
Replacement parts for WHIRLPOOL GU1500XTKT0 Undercounter Dishwasher | AppliancePartsPros.com Here is the tech sheet http://www.servicematters.com/docs/w...%208533399.pdf And a service manual https://secured.whirlpool.com/Servic...LE/8178022.pdf Does sound like your motor is toast.
__________________
| Display Modes | |
| Noisy Whirlpool Dishwasher: Replace just motor or whole pump&motor | mdion | Dishwasher Repair | 7 | 02-28-2011 01:31 PM |
| Frigidaire pump motor always on | Mike1635 | Dishwasher Repair | 1 | 10-30-2009 04:37 AM |
| motor/pump r&r | stevenealb | Dishwasher Repair | 0 | 04-24-2009 12:36 PM |
| help pump/motor | ezfried | Dishwasher Repair | 5 | 03-30-2009 06:16 PM |
| pump and motor noise | Mike G. Siano | Washer Repair | 0 | 08-17-2007 09:04 AM |
