Discuss
Kenmore won't drain
 in
Dishwasher Repair
The machine won't drain, I checked the drain hose for blockage, checked the drain port for blockage and found
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore won't drain
  #1 (permalink)
Old 07-03-2008, 10:47 AM
gschone gschone is offline
Junior Member
gschone is on a distinguished road
Default Kenmore won't drain
Model Number: 665.16033401   Brand: Kenmore   Age: 1 - 5 years
The machine won't drain, I checked the drain hose for blockage, checked the drain port for blockage and found nothing. I have the drain pump off and found water inside the armature casing behind the propeller.
HOW DO I CHECK TO SEE IF THE PUMP IS BAD???
WOULD THE WATER CAUSE IT TO NOT DRAIN???
When I ran it before disassembly water was flowing through the drain hose during the rinse/wash cycle.
Any ideas of what is wrong or how to diagnose it would be greatly appreciated.
Greg
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-05-2008, 08:32 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Greg,
Did you check the air gap on top of the sink (if there is one)?
Put the drain pump back, put the other end of the drain hose in a bucket and check how it'll drain.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore dishwasher will not drain waynel Dishwasher Repair 0 06-28-2008 03:30 PM
kenmore won't agitate, spin, or drain tcatt11 Washer Repair 0 02-20-2008 11:54 AM
Kenmore won't drain, pump ok! Susangopher Washer Repair 1 01-17-2008 07:06 PM
kenmore washer / 2 drain holes kathysmitley Washer Repair 2 12-14-2007 04:32 PM
kenmore washer / 2 drain holes kathysmitley Washer Repair 1 12-14-2007 12:20 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
