Discuss
dryer runs for few mins then shuts down
 in
Dishwasher Repair
no repairs have ever been done other than internal cleanings..it gets plenty hot,just have to wait for it
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dryer runs for few mins then shuts down
  #1 (permalink)
Old 07-02-2008, 04:39 AM
MJM MJM is offline
Junior Member
MJM is on a distinguished road
Smile dryer runs for few mins then shuts down
Model Number: LER5636E02   Brand: Whirlpool   Age: 5 - 10 years
no repairs have ever been done other than internal cleanings..it gets plenty hot,just have to wait for it to cool down,and will do same thing again,run for 5 mins and shut down,also my timerhas not been working,which means sometimes we forget we have laundrygoing and it was running for long periods..are either of these probs difficult for me to replace and repair? thanks,MJ
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-05-2008, 08:51 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi MJM,
The first thing I would do is check the exhaust line and the lint chute (#1 on the break down diagram) for any blockage. This is most common cause for long drying time and/or dryer overheating.
Also continues overheating may cause damage to the motor.
Here are the break down diagrams for the Whirlpool dryer Model LER5636EQ2
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 07-28-2008, 06:51 PM
MJM MJM is offline
Junior Member
Default Model LER5636EQ2
I replaced the timer motor,and it solved one of my problems...it now goes through its cycle,old one was sticking..but the same problem remains...runs for 5minutes then shuts off..after cooling down it will restart and repeat this pattern...dryer vent,dryer vent door,and internal duct all clear of any debris..on restart there are no strange sounds coming from dryer motor,nor at switch..any idea on what way I should go from here? model#LER5636EQ2...THANKS,MJ
  #4 (permalink)
Old 07-28-2008, 11:04 PM
MJM MJM is offline
Junior Member
Default Whirlpool Ler5636eq2
Hey Gene,Ichecked and cleaned everything in dryer.no blockage..it now will sometimes run a full dry cycle when it feels like it,to make this even more interesting..how often should the thermal fuse be replaced? the dryer is 10yrs old with same fuse.or could it be a bad thermostat??thanks MJ
  #5 (permalink)
Old 07-29-2008, 03:45 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Seems like a bad motor. I would check the motor for bad bearings.
__________________
  #6 (permalink)
Old 07-29-2008, 08:05 PM
MJM MJM is offline
Junior Member
Default
is this avisual check?...motor has never made any strange sounds..thermostat? or thermal fuse?would any of thesecause premature shutdown?
  #7 (permalink)
Old 07-30-2008, 04:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Run a simple test at the time when you can not restart it.
Open the dryer door, push and hold the door switch, push the start button and manually turn the drum. Post the results.
__________________
  #8 (permalink)
Old 07-30-2008, 10:16 PM
MJM MJM is offline
Junior Member
Default check
thanks Gene I will try that
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
runs for about 3 seconds and shuts off bigcamaro67 Microwave Repair 7 09-25-2008 01:15 PM
Gas Dryer Overheats & Shits Off after 10 mins crs2007 Dryer Repair 2 05-01-2008 06:29 AM
Stuck in defrost until unplugged for 30 mins eric0561 Refrigerator & Freezer Repair 2 02-15-2008 12:57 PM
runs for 2 min then shuts off...over and over agiain jklaehn01 Dryer Repair 1 01-09-2008 06:05 AM
dryer runs for awhile then shuts down before cycle is over guy stuller Dryer Repair 4 12-17-2007 06:42 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
