Discuss
Bosch dishwasher won't drain
 in
Dishwasher Repair
I came home to find two things 1. Burned electrical smell in the house 2. Dishwasher had failed to drain
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch dishwasher won't drain
  #1 (permalink)
Old 07-01-2008, 06:29 PM
downtube downtube is offline
Junior Member
downtube is on a distinguished road
Default Bosch dishwasher won't drain
Model Number: SHU33A06/22   Brand: Bosch   Age: 1 - 5 years
I cannot tell for sure if the two are connected, but it seems likely.
The filters were not clogged, and the drain impeller does not appear to be clogged. I find the impeller does not spin freely - it resists then moves in jerks. Kind of like turning a piston-driven shaft if you know what I mean.
I tried using the posted online manual to ohm-out the drain motor from the front panel, but the schematic for the SHU 33 does not appear to match mine (SHU33A06/22).
Suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-02-2008, 04:04 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
What it does when you push any buttons? Lights, sounds, e.t.c. ?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 07-02-2008, 07:46 PM
Junior Member
Default
Well that was interesting.
Yesterday it would run through a cycle like normal until it needed to drain, then made switching noises like it was trying to do something but could not. Eventually it appeared to be done (based on the lights) but the tub was full of water. I removed and cleaned all filters, which were not bad. Removed the pump cover and checked the impeller was not obstructed. Checked that the drain hose was not plugged.
Today, to answery your query precisely, I ran it through a cycle... and it worked fine. Running another cycle now, so we'll see.
  #4 (permalink)
Old 07-04-2008, 06:58 PM
Junior Member
Default
After three cycles with no problem, it's back to leaving the tub full of water. Seems to run through normally, but the tub is full of water at the end.
  #5 (permalink)
Old 07-05-2008, 06:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Possible a foreign object fluctuating in the drain line.
__________________
  #6 (permalink)
Old 11-29-2008, 09:17 PM
Junior Member
Default
Still no solution.
Symptoms:
- Burned electrical smell during cycle
- Tub is full of water at the end
What I've done:
Verified drain lines are clear
Verified drain hose has proper loop
Removed and inspected the circuit board - looks okay.
Replaced the drain pump.
- Old pump appears to be fine, after removal
- It ran two cycles normally after replacing the pump, then back to the
same failure mode.
Any troubleshooting suggestions?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Drain Hose on Bosch Dishwasher Lorenzo Dishwasher Repair 3 10-02-2008 12:31 PM
Bosch Dishwasher won't drain Little Lost one Dishwasher Repair 0 06-12-2008 01:30 PM
bosch dishwasher wont drain and complete cycle wcknudsen Dishwasher Repair 1 02-04-2008 06:28 PM
Bosch Dishwasher won't drain reisman Dishwasher Repair 4 12-27-2007 03:50 AM
Bosch Dishwasher Won't Drain jshoe01 Dishwasher Repair 2 09-06-2007 11:27 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
