| » Need flapper valve |
Model Number: GSD4620Z02BB Brand: GE Age: 5 - 10 years
Flapper valve located in check valve body is distorted and warped. Diagram does not show this particular flapper valve. Only shows the one in the pump housing. Is this flapper valve necessary and if so where can one be found? Thanks
Does not completely drain after final rinse cycle. Probably not completely draining after other cycles either because dishes are not getting as clean as they should. Replaced the discharge pump and in doing so, discovered the small flapper valve in the check valve body distorted. It is approximately 1 1/16" in diameter and the other flapper valve in the pump discharge is approximately 1 1/8" in diameter and has a marking that says "out" on one side of the flapper. Checked all areas for clogs and pipes for kinks and found none. Is it possible to operate the washer without the small flapper valve?
I assume you are talking about the piece that unscrews inside the tub with a spring and plunger. The bottom looks fine but there is a white rubber cone type washer at the top that looks pretty bad. Is that white piece at the top suppose to seal the hole at the top of the part? If so, it ain't doing it.
| Display Modes | |
| drain flapper not closing all way | rmattich | Dishwasher Repair | 3 | 01-03-2010 04:11 AM |
| flapper | gerard capobianco | Refrigerator & Freezer Repair | 0 | 12-29-2009 02:33 PM |
| Flapper trouble | ranhuntress | Refrigerator & Freezer Repair | 1 | 09-01-2009 09:20 PM |
| Ice Flapper Door | phoneimage | Refrigerator & Freezer Repair | 1 | 11-12-2008 10:08 AM |
| flapper check valve & beading for spray arm low | laineyo | Dishwasher Repair | 1 | 11-25-2007 07:21 AM |
