Discuss
dishwasher won't hold water in tub
 in
Dishwasher Repair
My Kitchen aid dishwasher won't hold the water in the tub. So that the dishes will wash. The water
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher won't hold water in tub
  #1 (permalink)
Old 09-06-2007, 03:04 PM
steve steve is offline
Junior Member
steve is on a distinguished road
Default dishwasher won't hold water in tub
Model Number: kuds23hbwh0   Brand: Kitchen Aid   Age: More than 10 years
My Kitchen aid dishwasher won't hold the water in the tub. So that the dishes will wash. The water is leaking out of the drain tube before the cycle is compleat. I have looked for a valve and it seems to be in the pump housing. Is there anything I can do short of buying a new one.
I like to tinker with stuff and my wife is just tight enough with the money to let me play most of the time. I really think she just wants me out of the house and in the shop for a while. HA!
Steve
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-11-2007, 05:11 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Under the washer, unscrew the drain fitting from the motor and check the check valve, a small black flexible flapper, probably warped.
__________________
  #3 (permalink)
Old 09-11-2007, 02:54 PM
Junior Member
Default
I removed the check valve and it seems to be clear, clean and working fine. However the water is still draining from the tub.
Help me understand dosn't the one way check valve just keeps the dirty water from returning to the tub?
  #4 (permalink)
Old 09-11-2007, 03:22 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Check the dishwasher drain hose under the sink. If the hose goes from the dishwasher directly in to the garbage disposer and it's sitting too low (5-10 inches from the floor), it will cause some of the water to drain out of the dishwasher. If that's the case, make a loop out of the drain hose, so that it's raised higher (2 feet or so).
A proper setup uses an airgap - see diagram.
richappy, that check valve is a pain, isn't it what engineer came up with that idea?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Old Caloric Oven: irregular ignition and won't hold a temperature mhrichardson99 Oven Repair (including Ranges and Cooktops) 1 12-08-2008 07:57 PM
Kenmore dishwasher not spraying water at the third level ilikebikes Dishwasher Repair 1 10-17-2007 04:34 PM
No Water Coming Into Dishwasher Momof3Girlz Dishwasher Repair 1 09-03-2007 09:11 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
