eyerobert
#1 Posted : Friday, May 7, 2010 12:10:36 PM(UTC)
eyerobert
After running hot water into the sink for 5 mins water began filling into bottom of the diswasher. We thought the sink and garbage disposer were partially clogged but it drains well. Is there a check valve to prevent drain water from entering the dishwasher?
Bob
#2 Posted : Saturday, May 8, 2010 2:04:17 AM(UTC)
Although not for your model here is a good dishwasher install sheet.
Check that your drain hose is installed correctly.
Please see the following install sheet
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=31-30515.pdf
