Discuss
lower spray arm
 in
Dishwasher Repair
I have a whirlpool GU980SCGQ3 that the lower arm is not spinning. this started a while ago and I wound
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » lower spray arm
  #1 (permalink)
Old 09-06-2007, 12:24 PM
jiml jiml is offline
Junior Member
jiml is on a distinguished road
Default lower spray arm
Model Number: GU980SCGQ3   Brand: Whirlpool   Age: 5 - 10 years
I have a whirlpool GU980SCGQ3 that the lower arm is not spinning. this started a while ago and I wound up cleaning it well which helped temp. there was a lot of soap crud at the bottom.
the upper arm spins fine. there does not seem to be anything blocking the holes on the lower arm. I dont see all that hard water/soap crud like last time. if I take off the lower arm there is some food paricles I see under a screen but I cant remove the screw (holding outlet pump )
to clean it. the lower arm does seem to not swing freely compared to a relatives that has a sim model. ther seems to be friction?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-10-2007, 09:38 AM
Junior Member
Default
it was the bearings and seal
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water backing up in the lower half of refrig. regiemister@hotmail.com Refrigerator & Freezer Repair 1 08-14-2007 11:50 AM
DW arms won't spray the water rflores Dishwasher Repair 1 08-07-2007 10:24 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
