Discuss
Whirlpool Motor does not start
 in
Dishwasher Repair
Hi All, My Whirlpool dishwasher DU890SWLQ0 is acting up. The motor is not started, and the water does not drain.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Motor does not start
  #1 (permalink)
Old 06-29-2008, 10:03 PM
vuacorona vuacorona is offline
Junior Member
vuacorona is on a distinguished road
Default Whirlpool Motor does not start
Model Number: DU890SWLQ0   Brand: Whirlpool   Age: 1 - 5 years
Hi All,
The motor has 4 pins, I tested continuity on the motor and it seem to be fine.
Please advise what else do I need to test?
Vua
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-30-2008, 03:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Vua,
Does the motor hums?
If it does then the problem is a stuck pump which has to be replaced in such case. In order to do it the dishwasher has to be removed from the cabinet.
- The part number for the pump & motor assembly is AP3044239
Here are the break down diagrams for the Whirlpool dishwasher Model DU890SWLQ0
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 06-30-2008, 05:56 PM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hi Vua,
Hi Gene and All,
thank you for your promptly replied.
yes the motor was hum for a bit, and now it stays silence.
Can you or anyone show me how to test this motor to make sure it is a dead motor.
  #4 (permalink)
Old 07-01-2008, 03:59 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Remove the torq screws holding down the pump cover and check for objects jamming the pump impeller.
__________________
  #5 (permalink)
Old 07-01-2008, 03:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by vuacorona View Post
...The motor has 4 pins, I tested continuity on the motor and it seem to be fine...
How did you do it?
You have to check for continuity between the "W-V" and "GY", "Y" & "BU-W".
Check for 120VAC between the "BU-W" and neutral while the control calls for wash and the door is latched.
Post the results.
__________________
  #6 (permalink)
Old 07-01-2008, 04:19 PM
Junior Member
Default
How did you do it?
Post the results.
What I did was test the continuity between all 4 pins in the motor.
Now can you elaborate about "W-V", "GY", "Y", "BU-W"
Sorry for an amateur question, because I am one and still learning.
v.
  #7 (permalink)
Old 07-01-2008, 04:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
...Now can you elaborate about "W-V", "GY", "Y", "BU-W"...
These are the colors of the wires plugged into the motor plug. "W-V" - white with violet strip, "GY" - grey, "Y" - yellow and "BU-W" - blue with white strip. You have to check for continuity between the motor terminals according to the wire colors on the plug.
__________________
  #8 (permalink)
Old 07-12-2008, 01:24 PM
Junior Member
Default
Hi Gene and All,
I checked for continuity at the motor terminals according to your instruction, and all 4 for pins have continuity to each other. So is this normal or something wrong with the motor?
  #9 (permalink)
Old 07-12-2008, 02:11 PM
Junior Member
Default
Hi Gene and All,
I also tried to turn the motor impeller as in the image below in both direction, but it stuck after little moved.
  #10 (permalink)
Old 07-13-2008, 04:15 PM
Junior Member
Default
All right, I just took the motor and the pump apart, and now the motor impeller can freely turning just fine.
However something stuck inside the pump that won't let the pump freely turning. This pump is appears to be sealed, how can I look inside the pump to see what stuck in there.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool dryer motor humms but won't start drum without help tsmith56 Dryer Repair 1 06-26-2008 05:20 PM
Motor Will Not Start Tub Without Assistance willm Dryer Repair 3 05-01-2008 07:22 AM
D.W. Motor failed to start brucethewineguy Dishwasher Repair 2 01-29-2008 05:18 PM
dw motor won,t start tmenter1 Dishwasher Repair 1 01-01-2008 01:56 PM
whirlpool washer motor needs help to start jes999 Washer Repair 3 12-16-2007 10:36 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
