Discuss
Whirlpool Motor does not start
 in
Dishwasher Repair
As I told you before, the problem is a stuck seal inside the pump. You can try to install a
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Motor does not start
  #11 (permalink)
Old 07-14-2008, 06:15 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
As I told you before, the problem is a stuck seal inside the pump. You can try to install a new impeller and seal kit. The disk-mount (#10 on the break down diagram) has to be replaced too. Replacing the whole pump and motor assembly makes such repair much more reliable.
- The part number for the impeller and seal kit is AP3108052
- The part number for the disk-mount is AP2909490
__________________
Professional appliance repair in Los Angeles, California.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool dryer motor humms but won't start drum without help tsmith56 Dryer Repair 1 06-26-2008 05:20 PM
Motor Will Not Start Tub Without Assistance willm Dryer Repair 3 05-01-2008 07:22 AM
D.W. Motor failed to start brucethewineguy Dishwasher Repair 2 01-29-2008 05:18 PM
dw motor won,t start tmenter1 Dishwasher Repair 1 01-01-2008 01:56 PM
whirlpool washer motor needs help to start jes999 Washer Repair 3 12-16-2007 10:36 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
