clutch removal
How is the clutch assembly removed? Once clip is removed, the clutch assembly does not come off. How hard is it to replace the clutch?
Once the clip is removed, it is removed by pulling it straight off the shaft, sometimes they are really stuck and need to be pryed off, using a screwdriver will help pry it off.
| All times are GMT -7. The time now is 06:29 AM. |
