Discuss
Bosch Dishwasher Won't Drain
 in
Dishwasher Repair
The dishwasher runs and never drains (even when I manually cancel/drain). I removed the control module and found a
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher Won't Drain
  #1 (permalink)
Old 09-05-2007, 07:56 PM
jshoe01 jshoe01 is offline
Junior Member
jshoe01 is on a distinguished road
Default Bosch Dishwasher Won't Drain
Model Number: SHU5306UC/U12   Brand: Bosch   Age: 5 - 10 years
The dishwasher runs and never drains (even when I manually cancel/drain). I removed the control module and found a significant burn thru the board near a solenoid?
My question are :
Should I just replace the control module and not worry about it?
Is this a common failure ?
Should I dig deeper to find what caused it ?
If more troubleshooting is required what and how (please)?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-05-2007, 11:15 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi jshoe01
At this time I would just replace the control board.
This is not a common failure for the Bosch dishwasher.
I would check the resistance though the drain motor terminals. It suppose to be about 16 Ohms.
- Here are the complete troubleshooting instructions for the Bosch dishwasher Model SHU5306 UC/12 (FD 8003-)
- The part number for the new control board AP2802870
Also I would recommend you to check all replies posted by our Bosch guru "loadster".
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 09-06-2007, 11:27 AM
Junior Member
Thanks Gene,
*If* the drain pump is bad, could that cause the solenoid to fry ?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Drain Hose on Bosch Dishwasher Lorenzo Dishwasher Repair 3 10-02-2008 12:31 PM
Bosch dishwasher Elise Dishwasher Repair 9 11-13-2007 04:46 PM
Bosch Dishwasher JohnM Dishwasher Repair 6 09-04-2007 09:06 AM
Bosch Dishwasher won't cycle dspecht Dishwasher Repair 2 08-15-2007 12:46 AM
Bosch dishwasher Elise Dishwasher Repair 2 08-13-2007 07:19 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
