Discuss
Kenmore Dishwasher Died
 in
Dishwasher Repair
My dishwasher died during a cycle and has no lights on the control panel. I used a voltage detector to
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore Dishwasher Died
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-25-2008, 06:54 PM
Steel4Wire Steel4Wire is offline
Junior Member
Steel4Wire is on a distinguished road
Unhappy Kenmore Dishwasher Died
Model Number: 665.15822000   Brand: Kenmore   Age: 1 - 5 years
My dishwasher died during a cycle and has no lights on the control panel. I used a voltage detector to check for power and found the following:
  • when the door switch is actuated - power can be detected at the thermal fuse - on and off as the switch is actuated and let go. This seems to be working properly. I even tried removing the fuse and jumping it out - no dice.
  • the Thermal fuse is intact and power goes beyond into the control board.
  • i purchased a new control board for $100 and popped it in and guess what.......right... it didn't work.
I'm about to lose it and I gotta get this thing fixed.....Please help!!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-26-2008, 03:59 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would do is verify if there is 120VAC between the hot and neutral wires with a voltmeter. Detector will show power but if there is no proper voltage - the dishwasher will never work. Also verify if there is no reversed polarity at the dishwasher junction box (under the dishwasher).
Post your findings.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electronic control died twice mschabb Dishwasher Repair 0 06-18-2008 03:29 PM
Kenmore just died - no sign of life mthierfelder Microwave Repair 18 06-04-2008 04:12 PM
Disposer died! Leslie Garbage Disposer Repair 7 05-04-2008 08:01 AM
Kenmore Dishwasher adrian Dishwasher Repair 1 03-21-2008 08:16 AM
Dryer Died? BZYMOM Dryer Repair 2 10-05-2007 02:22 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
