| » Problem with SmartDispense on GE Profile DW |
Sorry so many questions, just confused because it works everytime I show a customer how to do it. At anypoint did you try to kill the power to it and try again? Disconnect power for about a minute and try again
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
Same results. I really appreciate your help. At this point what I'm considering is removing the pump (without removing the resevoir) so that I can use a stiff wire to clean the nipple at the end of the bottle. After replacing the pump I'll put a cup, or so, of warm water in the resevoir and let it run a normal cycle. Maybe that'll get it going.
That's an option. If you can't get it unclogged, you can buy just the collar and seals if you need to remove the bottle, but you will need a strap wrench to remove the collar.
__________________
Well, I removed the pump and it was plugged into the tube on the pump. Since I already had a new one I replaced it anyway. I ran a stiff wire up from the bottom of the detergent bottle and it appears that all is working now. I also did some web browsing on the GE Knowledge base. I found the purge instructions. There was a minor, but important difference. In step 3 it said to press "Added Heat" and "Cookware" together. In the instructions you sent it said "Added Heat" and "Normal". It is running a purge now.
Again, thanks for your help. |
I copied and pasted those instructions to you, great work on finding that subtle but important difference. I will pass that along to the team in charge of that stuff.
__________________
I also edited the instructions in the post to include the PDW8600 series dishwashers.
__________________
| Display Modes | |
| Washer problem in LARGE load setting- timer problem? | jagtianis | Washer Repair | 9 | 08-04-2008 03:49 AM |
| GE Profile Stove Top Burner Problem | martys | Oven Repair (including Ranges and Cooktops) | 6 | 07-23-2008 07:39 PM |
| Ge profile fill problem | Danfros | Dishwasher Repair | 2 | 04-15-2008 06:59 AM |
| Thanksgiving Oven Problem.....its still a Problem! | rbmattila | Oven Repair (including Ranges and Cooktops) | 1 | 03-03-2008 10:05 AM |
| Ge Profile XL44 Burner Problem | djdresden | Oven Repair (including Ranges and Cooktops) | 0 | 02-23-2008 12:56 PM |
