Discuss
Problem with SmartDispense on GE Profile DW
 in
Dishwasher Repair
Sorry so many questions, just confused because it works everytime I show a customer how to do it. At anypoint
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Problem with SmartDispense on GE Profile DW
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #11 (permalink)
Old 06-26-2008, 10:59 AM
abadfish66's Avatar
abadfish66 abadfish66 is online now
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Sorry so many questions, just confused because it works everytime I show a customer how to do it. At anypoint did you try to kill the power to it and try again? Disconnect power for about a minute and try again
__________________
I won $12,000 last year playing FantasyFootball on WWW.Dimesports.net, this was my first year playing fantasy football. Sign up and use Promocode 152, and my e-mail abadfish66@cox.net for special pricing. My team name is Hawks, and My testimonial is on the main page
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #12 (permalink)
Old 06-26-2008, 11:13 AM
danosgood danosgood is offline
Junior Member
danosgood is on a distinguished road
Default
Same results. I really appreciate your help. At this point what I'm considering is removing the pump (without removing the resevoir) so that I can use a stiff wire to clean the nipple at the end of the bottle. After replacing the pump I'll put a cup, or so, of warm water in the resevoir and let it run a normal cycle. Maybe that'll get it going.
  #13 (permalink)
Old 06-26-2008, 11:20 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
That's an option. If you can't get it unclogged, you can buy just the collar and seals if you need to remove the bottle, but you will need a strap wrench to remove the collar.
__________________
  #14 (permalink)
Old 06-26-2008, 01:11 PM
Junior Member
Default
Well, I removed the pump and it was plugged into the tube on the pump. Since I already had a new one I replaced it anyway. I ran a stiff wire up from the bottom of the detergent bottle and it appears that all is working now. I also did some web browsing on the GE Knowledge base. I found the purge instructions. There was a minor, but important difference. In step 3 it said to press "Added Heat" and "Cookware" together. In the instructions you sent it said "Added Heat" and "Normal". It is running a purge now.
Again, thanks for your help.
  #15 (permalink)
Old 06-26-2008, 01:16 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
I copied and pasted those instructions to you, great work on finding that subtle but important difference. I will pass that along to the team in charge of that stuff.
__________________
  #16 (permalink)
Old 06-26-2008, 01:24 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
I also edited the instructions in the post to include the PDW8600 series dishwashers.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer problem in LARGE load setting- timer problem? jagtianis Washer Repair 9 08-04-2008 02:49 AM
GE Profile Stove Top Burner Problem martys Oven Repair (including Ranges and Cooktops) 6 07-23-2008 06:39 PM
Ge profile fill problem Danfros Dishwasher Repair 2 04-15-2008 05:59 AM
Thanksgiving Oven Problem.....its still a Problem! rbmattila Oven Repair (including Ranges and Cooktops) 1 03-03-2008 09:05 AM
Ge Profile XL44 Burner Problem djdresden Oven Repair (including Ranges and Cooktops) 0 02-23-2008 11:56 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
