Discuss
water drains before washing dishes
 in
Dishwasher Repair
The dishwasher runs though it's cycles but it does not wash dishes and the soap is not used. It
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » water drains before washing dishes
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-25-2008, 11:10 AM
dgk1173 dgk1173 is offline
Junior Member
dgk1173 is on a distinguished road
Default water drains before washing dishes
Model Number: GSD2230Z02WW   Brand: GE   Age: 5 - 10 years
The dishwasher runs though it's cycles but it does not wash dishes and the soap is not used. It appears as though the water is drained out of the washer before the wash or rinse cycles can swirl the water in the washer. I say this by listening to the washer. Makes noise during the cycles but no noise of swirling water. There is water draining from the washer at various points in the cycle so water is going into the washer. Appears it is not being used or drained prematurely. Thanks for any help
Krish
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-25-2008, 11:14 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
It may not be getting enough water to begin with, start a cycle and when the water stops filling, open the door and check water level. Also where does the drain line connect to, an airgap at the sink, or through the garbage disposer
__________________
I won $12,000 last year playing FantasyFootball on WWW.Dimesports.net, this was my first year playing fantasy football. Sign up and use Promocode 152, and my e-mail abadfish66@cox.net for special pricing. My team name is Hawks, and My testimonial is on the main page
  #3 (permalink)
Old 06-25-2008, 11:45 AM
Junior Member
Default
Thanks for the prompt response.
The drain goes to the airgap and then to the garbage disposal. I can stop the drain at the garbage disposal and the water comes out of the Airgap, so I presume that works. I have openeed the washer door at various points in the cycle and find some water but not very much at the bottom some times I find none. However when it drains there is a lot of water draining (I think). Thanks for the help.
  #4 (permalink)
Old 06-25-2008, 11:48 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Ok, but do as I said before, start a cycle and as soon as the water stops filling, open the door and check water level, need to make sure it starts with enough water.
__________________
  #5 (permalink)
Old 06-25-2008, 12:19 PM
Junior Member
Default
I did what you said. There is no water. The draining seems to coincide with the water fill leaving no water in the washer. I cannot identify the water fill cycle, only the water drain cycle, due to the noise of the drain cycle. In addition there is small water leak on to the solenoid each time it is activated and then the leak stops. The bottom of the solenoid is rusty and there is calcium deposit on the floor so it must have been leaking and drying for a while. Thanks for the help
  #6 (permalink)
Old 06-25-2008, 12:28 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
I'm trying to understand, your saying that as it is filling the solenoid is in the down position and draining. Does the solenoid move up and down each time it hits the drain cycle. If the solenoid is leaking you will need a new motor assembly to fix that.
__________________
  #7 (permalink)
Old 06-25-2008, 12:37 PM
Junior Member
Default
The solenoid makes a small movement down and immediately back up every time I open the door. Each time it makes this move down and back up there is a small amount of water that trickles down on to the solenoid and then the trickle stops. It also begins to drain at this time. This same movement of the solenoid happens when I first start the washer. Thanks for the help.
  #8 (permalink)
Old 06-25-2008, 12:43 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
ok, now on the front control of the dishwasher, what does the second button from the left feel like, push it, I think this is the heated dry on / off button, it should feel good, or is there some resistance or alot of slop in the switch, or is it stuck and wont move.
__________________
  #9 (permalink)
Old 06-25-2008, 12:50 PM
Junior Member
Default
The heated dry on/off buttons work fine. When the On button is pushed the Off button pops out and vice versa. They feel good. No slop, not stuck and there is no abnormal ressistance.
  #10 (permalink)
Old 06-25-2008, 01:00 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Disconnect the drain solenoid and star a cycle, see if it will fill with water
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washing machine fills and drains same time imagiggles Washer Repair 2 07-17-2008 11:36 PM
Fills,drains but doesn't clean the dishes jahfy Dishwasher Repair 0 04-06-2008 10:21 AM
Diswasher drains water out during wash cycle vschnoebelen Dishwasher Repair 1 01-04-2008 10:48 AM
Washing dishes lsternberg Dishwasher Repair 0 11-20-2007 08:39 AM
Water doesn't drain, spotty dishes cherienoel Dishwasher Repair 1 09-16-2007 06:24 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
