Discuss
DW runs for 15 seconds and stops
 in
Dishwasher Repair
I have seen posts similar to this but none exactly the same. My stop does not appear to be occurring
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » DW runs for 15 seconds and stops
  #1 (permalink)
Old 06-23-2008, 07:36 AM
verbeek1 verbeek1 is offline
Junior Member
verbeek1 is on a distinguished road
Default DW runs for 15 seconds and stops
Model Number: KUDI01TJWH0   Brand: Kitchen Aid   Age: 5 - 10 years
I have seen posts similar to this but none exactly the same. My stop does not appear to be occurring midcycle. I base this on the fact that the DW was dry and the dishes appeared clean from the previous wash. (I am open to admitting these could both be bad assumptions though.) When the wife goes to start the next load the unit makes a low motor sounds (not strained or grinding & no water movement) for 10-15 seconds and then the water heater light turns on for a second or two and then everything stops. Nothing else will happen no matter what button you push. If you push a different cycle like Heavy, it just blinks several times and reverts back to Normal. From reading this forum, I have attempted a few basic checks. I shut the power down to reset the board. I checked the water float to make sure that it was free. I also saw a diagnotic suggestion to add 2" of water to the tub and see what would occur. I tried it and the symptoms now change slightly. The unit now sprays water and washes for 10-15 seconds, the water heater light comes on once and then the unit shuts down again. The Cancel/drain button doesn't work either so I now have 2" inches of stinky water to content with.
Seen this before? Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-23-2008, 09:56 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad control board (#11 on the break down diagram).
- The part number for the control board is AP3775964
Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDI01TJWH0
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
runs for about 3 seconds and shuts off bigcamaro67 Microwave Repair 7 09-25-2008 01:15 PM
Microwave stops after 59 seconds Nessguy Microwave Repair 1 04-22-2008 04:21 PM
Sharp Micro Only runs for 59 seconds attitude Microwave Repair 0 04-22-2008 03:59 PM
Maytag Dryer Stops after 30 seconds austein Dryer Repair 4 01-03-2008 09:28 PM
compressor runs for a few seconds, clicks and then nothing gconnors Refrigerator & Freezer Repair 1 11-03-2007 03:59 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
