| » water not spraying from the lower and upper arm |
Model Number: GU1200XTLQ0 Brand: Whirlpool Age: 1 - 5 years
Ok, after reading all the posted on the impeller removal, I order one, I took my whole assembly apart I see what my problem was that cause the impeller to brake,I removed the old, now I’m have problem installing the new impeller
The shaft of the motor has thread and the new impeller suppose to screw onto the shaft With the engineering caliper I measure the size of the thread on the motor shaft is (.3 of inches) but the hole on the impeller is only (.2 of inches), I have tryed to force the impeller on but with no luck, can you place tell me what I’m doing wrong should I try to re-thread the impeller with TAP to larger size, the part number I order is WPL 819351 please help Ads By Google Related Models |
| Display Modes | |
| Separate fuses for upper & lower? | jrfiero | Oven Repair (including Ranges and Cooktops) | 2 | 01-10-2010 02:36 AM |
| upper and lower arms do not spin | angelgirl1960 | Dishwasher Repair | 1 | 01-05-2010 07:01 PM |
| Dishwasher lower are not spraying or moving | Patricia Ratliff | Dishwasher Repair | 3 | 01-05-2010 06:00 PM |
| Lower Washer Arm Not turning or spraying | Patricia Ratliff | Dishwasher Repair | 0 | 01-02-2010 05:00 AM |
| water not spraying from the lower and upper arm, | jamesg | Dishwasher Repair | 3 | 06-25-2008 09:41 AM |
