dishes not being cleaned on the upper rack. I know the upper arm isn't spinning because beginning with the third fill, action switches between the lower and upper spray arm in 90 second intervals acording to the manual. I have stopped the washer to see the spin but none. The manual also says water passes through the fine mesh primary filter where food soil is removed and the clean water is recirculated. Where can I find this filter to see if it is blocked?
Thank You
