Discuss
dishwasher sprayarm problem
 in
Dishwasher Repair
I have a loose upper sprayarm. If I replace the arm itself, will a new one stay put or is
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher sprayarm problem
  #1 (permalink)
Old 09-04-2007, 08:24 PM
ghcusic ghcusic is offline
Junior Member
ghcusic is on a distinguished road
Default dishwasher sprayarm problem
Model Number: GSD5500G00WW   Brand: GE   Age: 1 - 5 years
I have a loose upper sprayarm. If I replace the arm itself, will a new one stay put or is there apt to be a problem with the plastic pieces that hold it?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-05-2007, 12:02 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi ghcusic
What spray arm are you talking about: the middle spray arm (#618 on the tub & dish racks break down diagram) or the 3rd level spray arm (#570 on the tub & dish racks break down diagram)?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 09-05-2007, 08:15 AM
Junior Member
Default
Gene,
The sprayarm is for the third level, #570 on the diagram. It falls off with each washing. Have you had this problem before?
  #4 (permalink)
Old 09-05-2007, 10:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi ghcusic
I do not remember how this spray arm should be mounted to the dishwasher, but I believe if you buy the new one you'll be able to figure it out. If you'll find it should be screwed then it's possible you have to remove the dishwasher from the cabinet.
- The part number for the new 3rd level spray arm assembly AP3184058
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
