Discuss
Dishwasher fills with water - does not clean
 in
Dishwasher Repair
I have a Frigidaire dishwasher that will fill with water and run through the cycles, but it does not clean
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher fills with water - does not clean
  #1 (permalink)
Old 06-18-2008, 04:42 PM
FixingIt FixingIt is offline
Junior Member
FixingIt is on a distinguished road
Default Dishwasher fills with water - does not clean
Model Number: GPDB998JC0   Brand: Frigidaire   Age: 5 - 10 years
I have a Frigidaire dishwasher that will fill with water and run through the cycles, but it does not clean the dishes. I listened to it run and I do not believe the sprayers are turning. Is this the motor or the sprayer?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-18-2008, 07:16 PM
Junior Member
Default
It is definitely that the sprayer is not turning. Water is coming up through the sprayer, but it does not turn. Motor or just a part of the turning mechanisim?
  #3 (permalink)
Old 06-19-2008, 06:49 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
It could be not enough water or a problem with the wash pump.
__________________
Professional appliance repair in Los Angeles, California.
  #4 (permalink)
Old 06-21-2008, 11:56 AM
Junior Member
Default
Do you think it is the pump or the inlet water valve?
  #5 (permalink)
Old 06-22-2008, 02:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It has to be tested. Guessing is most expensive way to fix appliances.
__________________
  #6 (permalink)
Old 06-23-2008, 04:34 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Dump a few gallons of water in the dishwasher and see if it now works, if so, you might have a partially clogged screen in the water solenoid.
If still not ok, remove the pump cover and check for something blocking the pump.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher fills and drains but won't spray water around dawgface21 Dishwasher Repair 0 06-18-2008 10:38 AM
Bosch dishwasher fills, drains, fills again then stops ricsan Dishwasher Repair 1 06-05-2008 04:40 AM
Fills,drains but doesn't clean the dishes jahfy Dishwasher Repair 0 04-06-2008 11:21 AM
water over fills janetvee Refrigerator & Freezer Repair 0 03-25-2008 07:40 AM
Tub fills with water JoelK Dishwasher Repair 3 01-23-2008 02:03 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
