Discuss
Old Kitchen Aid heater control
 in
Dishwasher Repair
Everything about this unit works, except the heater does not come on to heat the water. The heater element works,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Old Kitchen Aid heater control
  #1 (permalink)
Old 06-18-2008, 07:42 AM
Caldwell Caldwell is offline
Junior Member
Caldwell is on a distinguished road
Default Old Kitchen Aid heater control
Model Number: KUDC210s2   Brand: Kitchen Aid   Age: More than 10 years
Everything about this unit works, except the heater does not come on to heat the water. The heater element works, because it heats up during dry cycle. I looked at parts diagrams, don't see an aquastat or other obvious temp control to make a connection to turn on the heater during the wet cycles.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-18-2008, 09:34 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Check for continuity across the "AH" & "HS" terminals on the push button switch. Check the heating element for continuity too even if it seems to be hot at the end of the cycle.
If there is nothing wrong then the timer has to be replaced.
- The part number for the timer is AP3124204
Here are the break down diagrams and the wiring diagram for the Kitchen Aid dishwasher Model KUDC210S2 .
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Heater not working fluffy4555 Refrigerator & Freezer Repair 1 05-15-2008 07:09 AM
defrost heater Kenny Duke Refrigerator & Freezer Repair 1 03-19-2008 02:10 PM
Heater sub-assembly dupontjams Dryer Repair 1 02-28-2008 02:18 PM
Defrost heater Johnkut Refrigerator & Freezer Repair 9 12-26-2007 07:28 PM
defrost heater Ashman Refrigerator & Freezer Repair 0 07-31-2007 02:13 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
