Discuss
dishwasher won't start new wash cycle
 in
Dishwasher Repair
I can not start a new wash cycle.The dishwasher finished its wash cycle and the clean light is lit
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher won't start new wash cycle
  #1 (permalink)
Old 06-17-2008, 09:46 PM
Bumkus Bumkus is offline
Junior Member
Bumkus is on a distinguished road
Default dishwasher won't start new wash cycle
Model Number: DU1050XTPT3   Brand: Whirlpool   Age: 1 - 5 years
I can not start a new wash cycle.The dishwasher finished its wash cycle and the clean light is lit up but when trying to start a new wash cycle it lights the cycle light but when you push the start button it goes back to the clean light button. If i push cancel and drain it will, but can not start a new wash cycle.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-18-2008, 08:29 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Does the "clean" light stays solid or it's blinking?
If it stays solid, would it go "off" if you open and close the door?
Try to unplug the power cord (under the sink) for a few minutes. Sometime it helps to eliminate a problem.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 06-19-2008, 07:11 PM
Junior Member
Default
clean light is blinking. I tried opening and closing the door and also killed the power to it but it didn't change anything.
  #4 (permalink)
Old 06-19-2008, 07:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The clean light blinking seven times in a row means the control senses a problem with the heat circuit. Look into the complete manufacturer instructions to solve the problem.
Here are the tech sheets for your dishwasher.
__________________
  #5 (permalink)
Old 06-20-2008, 08:57 PM
Junior Member
Default
Thanks Gene for the info. I almost went and bought a new board. So far everything seems to be working fine. I know after three cycles it should detect a problem but so far so good.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher Hums during wash cycle hamiltona Dishwasher Repair 0 05-12-2008 06:36 PM
Frigidaire dishwasher sticking in wash cycle needs help Dishwasher Repair 5 05-02-2008 11:22 AM
viking dishwasher wash cycle not working ronald carter Dishwasher Repair 1 04-29-2008 08:01 PM
wash cycle stops 10 minutes after start fullhouse Washer Repair 1 03-20-2008 05:46 PM
Dishwasher skips the wash cycle and stops at the rinse cycle jasporo Dishwasher Repair 1 11-16-2007 06:12 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
