Discuss
bosch diswasher-lower door seal
 in
Dishwasher Repair
Hi, Hoping someone can give me some advise on replacing a lower door seal on the above mentioned dishwasher. 1)
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » bosch diswasher-lower door seal
  #1 (permalink)
Old 06-17-2008, 09:43 AM
inmysights inmysights is offline
Junior Member
inmysights is on a distinguished road
Default bosch diswasher-lower door seal
Model Number: shu4312uc/u06   Brand: Bosch   Age: 5 - 10 years
Hoping someone can give me some advise on replacing a lower door seal on the above mentioned dishwasher. 1) do all the stainless steel panel screws need to be removed or can i just remove the ones closest to the seal in order to get enough room to slide th old seal out and new one in.
2) Do all 4 screws on the door arm need to be removed or is it sufficient to remove the front two which seem to anchor the seal bracket. If all screws need to be removed how do i deal with the tension on the door arms. Not sure if I'm even approaching the problem correctly. Step by step instructions would be appreciated .Thanks for any advise you can provide
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lower Door Seal Installation DougB Dishwasher Repair 4 08-02-2008 02:12 PM
maytag diswasher door-- heavy ruthk Dishwasher Repair 1 05-20-2008 04:05 PM
Bosch diswasher runs but doesn't drain michaelleonardburrows@yah Dishwasher Repair 4 01-09-2008 09:46 PM
New lower door seal is too narrow and leaks kkayaker Dishwasher Repair 4 12-14-2007 12:04 AM
Water leaking under door...need to know how to remove door & replace seal edbolliera Dishwasher Repair 1 11-27-2007 04:42 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
