Discuss
water not spraying from the lower and upper arm,
 in
Dishwasher Repair
I have whirlpool model GU1200XTLQ0 and I have problem with water not spraying from the lower and upper arm, what
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » water not spraying from the lower and upper arm,
  #1 (permalink)
Old 06-15-2008, 10:06 AM
jamesg jamesg is offline
Junior Member
jamesg is on a distinguished road
Default water not spraying from the lower and upper arm,
Model Number: GU1200XTLQ0   Brand: Whirlpool   Age: 1 - 5 years
I have whirlpool model GU1200XTLQ0 and I have problem with water not spraying from the lower and upper arm, what I’ve read is it’s probably the impeller section, so I taking the whole thing apart, I ordered the new part, not here yet, but how does the impeller that’s on the motor come apart, I read you have brake because it’s glued on, so my question how does the new goes on the motor, do I have to order the glue
Thanks for you’re help
Regards
James
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-20-2008, 12:21 PM
Junior Member
Default
Please can someone help me out, I received the for the impeller from appliance parts, but still have no idea how the new part stay on the shaft after removing the old one, thanks
  #3 (permalink)
Old 06-24-2008, 05:27 AM
okbobcats okbobcats is offline
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default chopper
Does the pump turn and move easy. Are u sure you just did not have some junk in the chopper area. Which would block the water from reaching the pump. Really have not seem to many pumps go bad. Motors yes. Check the chopper area for junk.
  #4 (permalink)
Old 06-25-2008, 10:41 AM
Junior Member
Default
Thank for the reply, yes to answer your question the motor is running fine but the copper was clogged with junk, but the impeller has plastic part that connects to the copper section to rotated, do to the junk it worn out the plastic, so I had to replace it, but my problem was the new impeller hole was made for (.2 inch) screw but the shaft of the motor is (.3 inch in diameter), so I had to enlarge using 5/16 TAP and everything is fine,
Regards
James
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lower arm seems to work, middle & upper not working n3jhv Dishwasher Repair 4 11-07-2008 07:41 AM
No water in upper spray arm caveman Dishwasher Repair 0 02-12-2008 09:03 AM
Americana Range with upper and lower oven effinsyv Oven Repair (including Ranges and Cooktops) 1 12-18-2007 07:11 AM
Kenmore dishwasher not spraying water at the third level ilikebikes Dishwasher Repair 1 10-17-2007 04:34 PM
upper and lower burners not consistent artkat Oven Repair (including Ranges and Cooktops) 0 09-28-2007 03:29 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
