ptm526
#1 Posted : Saturday, June 14, 2008 5:22:51 AM(UTC)
ptm526
Washers cycles thru all cycles and pumps some water into the sink drain. Washer doesn't have an air gap. Checked drain hose for obstructions, check drain areas of washer. After final rinse cycle there is a substantial amount of water remaining in the bottom. If the "start/reset" button is pressed, the " washing cycle" light starts blinking and the remaining water is pumped out. Any suggestions? Thanks.
