Hello The problem I am seeing is with the soap dispenser. I can manually close and open it. It does close with the soap in it. However, sometimes, I see a trail of soap on the door and most of it at the bottom (pan?). Not sure what is going on. The entire plastic assembly seems brittle and appears to have residual coating (me thinks it could be soap). :confused:
Can't find a ref to such problem for the model. I see other model but parts seem to be different. The control module was replaced already as part of the recall but doesn't seem related.
Finally, is there a sticky on how to read the Error codes and what they mean for this model? Thanks from a newbie.
