:confused:I have a ge pot scrubber 600 model gds600d-03. I am installing a new redesigned pump. The old pump has a wire hanger that hooks in to the back of the pump motor and goes through a whole in the galvanized metal dishwasher frame and then the other end of the hanger has a loop that is bolted to the front of the motor. The new pump has different hanger or brackets one is similar to the old hanger but doesn't hook into the back of the new motor like the old one but seems to appears to go through the same hole in the galvanized dishwasher frame to the front of the pump and may be bolted to a point on the motor in the front but there are no directions. I am not sure though. there is also a different longer bracket or hanger that has 2 loops bent on the ends which look like they take a small bolt to go threw and bolt to some where. I thought maybe to a front plate on the dishwasher and also to a point on the motor but I am not sure though. Can anyone tell me where the bracket gets mounted to? There are not directions. cell phone 908-546-8434 Sincerely David:)
