Dish washer stop running during the drain cycle. in about ten minutes it started running again. Thought something might be lodge so cleaned out drain line and all around the fins. Started pumping water out but was making this grainding nosie. Tour it down to all you could see was the motor shaft. It spun free and I turned it on and no noise. soSo do I need to replace the two impelers?
