Discuss
Rotator arm won't, rotate that is.
 in
Dishwasher Repair
Okay, so the lower rotating arm won't rotate, so I removed the outlet pump cover and got down to
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Rotator arm won't, rotate that is.
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-01-2007, 10:55 AM
dragonlady dragonlady is offline
Junior Member
dragonlady is on a distinguished road
Red face Rotator arm won't, rotate that is.
Model Number: DU8700XY-4   Brand: Whirlpool   Age: 1 - 5 years
Okay, so the lower rotating arm won't rotate, so I removed the outlet pump cover and got down to the drain and wash impeller. I need to get this off so I can get the screw I dropped out from under the pump. Anyway, how do I get the drain and wash impeler off. I removed the screw, and the impeller turns freely, but I can't tell how to get it off/out. I would like to clean the filter screen while I'm at it but don't know if there is one. Don't see one in the exploded diagram I got off the internet. So that's where I'm at, HELP!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-01-2007, 01:28 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi dragonlady
In most cases it's not possible to remove the wash impeller without breaking it in pieces. If you really want to do it you have to have the new impeller kit (#11, #19 or #24 on the pump & motor break down diagram).
If the pump is not leaking and it moves freely it does not need any service.
One of the most common cause for the lower spray arm not to spin properly is insufficient amount of water inside the dishwasher. Check the water shut off valve under the sink to see if it's open all the way.
If this not an issue then the water inlet valve (#16 on the tub assembly break down diagram) has to be replaced.
- The part number for the new water inlet valve AP3010773
- The part number for the new impeller kit AP3115180
- The break down diagrams for the Whirlpool dishwasher Model DU8700XY4
Good luck.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fan does not rotate when turned on so no cold air comes out just alot of noise SKEET21 Heating, Ventilation, and Air Conditioning (HVAC) 1 08-03-2007 10:37 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
