Don Kidwell
#1 Posted : Sunday, March 21, 2010 3:50:45 AM(UTC)
Don Kidwell
Washer goes through every cycle but wont spin, just makes humming noise
gmbdinc
#2 Posted : Sunday, March 21, 2010 7:00:00 AM(UTC)
gmbdinc
Sounds Like the motor Part number: AP2905451
However, you can feild test a few things w/o meters, Unplug the machine take off the outer shell, seperate the pump from the motor without disconnecting the hoses, ... by pass the lid switch...plug it back in.. put the timer in spin and start If it spins, there is a problem with the pump (sock or something check it out.) Part number: AP3963893
If the motor does not spin, then seperate the motor from the transmission. Find a way to hold the motor" in place on the floor"...connected to the wiring harness. By-pass the lid switch... plug the washer back in... move the timer to a spin setting.(HOLD OR SECURE THE MOTOR IN PLACE!!!) and pull the timer knob. If the motor does not kick immediately, replace the motor.
I realize this was a littly "windy" but I hope is helps.
Whirlpool washer doesnt spin (Washer Repair)
by yoyopol2000 10/22/2012 10:09:45 AM(UTC)
