Wouldn't drain, so I read the threads and cleaned out the gunk and reassembled the filter and impeller. I put the two check balls in the drain, where it shows them on the diagrams (available elsewhere). The unit drains fine.
Now the unit is noisy when it drains. :eek: Did I get something wrong with the reassembly? Is there some trick to aligning the parts even though I didn't take out the motor or an other parts not on the spindle? Will this go away with a full cycle rather than just a few minutes from quick rinse?
Thanks, Brad
