this mixer is used very little maybe 2 hours on it.
I took it out wipes up in around the planetary and noticed oil on my cloth, but does not drip. I put on the grinder, when the meat was done grinding, and I was cleaning up I noticed the attachment tube had oil/grease on it and also some on the inside of the hopper where the grinder plunger goes into Do I need A new seal where it has set so long without use (maybe 5 yrs) and if I do is it available and what is the cost thank you for your help Carmen
