flysrv10
#1 Posted : Sunday, March 14, 2010 9:24:19 AM(UTC)
flysrv10
Hello, my dish washer does not drain. the hose is clear. Is there another area on this model that I need to check. thank you for your help.
#2 Posted : Monday, March 15, 2010 2:41:53 AM(UTC)
Replacement parts for WHIRLPOOL KUDM01TJBS0 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208269519.pdf
And a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4e8b0d2df77cd7e585256cd800643b6d/$FILE/KD01.pdf
Could be clogged drain.
Remove the drain hose from the house plumbing and drain it into a pail.
Hold the hose securely in the pail and also put a towel over it unless you want a shower.
They often clod up where the drain hose goes over the house plumbing fitting.
Can you hear the drain pump running?
If not measure the voltage across it when it should be running.
If it is 0 volts then you probably have a control board problem.
If there is 120 volts then either you have a plug in the system or the drain pump is toast.
flysrv10
#3 Posted : Monday, March 15, 2010 4:04:14 AM(UTC)
flysrv10
Thank you for the quick response. Will check it further this weekend.
flysrv10
#4 Posted : Wednesday, March 17, 2010 3:01:02 AM(UTC)
flysrv10
Hosde was clogged deep deep inside. problem solved. thank you again.
