Discuss
Problem reconnecting wire to heat element
 in
Dishwasher Repair
I am installing a new electronic control board in my Kenmore dryer and when I went to reconnect the wires,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Problem reconnecting wire to heat element
  #1 (permalink)
Old 05-27-2008, 04:32 PM
Loriabrass Loriabrass is offline
Junior Member
Loriabrass is on a distinguished road
Default Problem reconnecting wire to heat element
Model Number: 110.60094991   Brand: Kenmore   Age: 5 - 10 years
I am installing a new electronic control board in my Kenmore dryer and when I went to reconnect the wires, I cannot remember which of the two wires goes into which socket of the heat control on the board. Which of the two wires (red and black) goes into which socket?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-28-2008, 03:01 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Check for the wiring diagram inside the control panel or behind the front access panel. If you do not have one, you can order it.
- The part number for the wiring diagram is AP3970785
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Timer Wire problem deleriousone Dryer Repair 17 08-06-2008 02:21 PM
Burnt Wire to Heating Element Trigger2 Dryer Repair 0 05-21-2008 12:10 PM
unable to find element wire homebuilder0481 Oven Repair (including Ranges and Cooktops) 1 01-31-2008 04:45 PM
Maytag CRE9400CCE Bake element LEAD wire COLOTOM Oven Repair (including Ranges and Cooktops) 1 12-24-2007 02:25 PM
Infinite Wire Switch Dual Element leighr3 Oven Repair (including Ranges and Cooktops) 1 12-11-2007 02:04 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
