Discuss
Bosch Stuck in Drain Cycle; even with door open
 in
Dishwasher Repair
This machine has been a problem almost from day 1! It has been over hauled several times do to electronic
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Stuck in Drain Cycle; even with door open
  #1 (permalink)
Old 03-10-2010, 07:16 PM
Junior Member
toungetwster is on a distinguished road
Default Bosch Stuck in Drain Cycle; even with door open
Model Number: SHY56A   Brand: -brand-   Age: 1 - 5 years
This machine has been a problem almost from day 1! It has been over hauled several times do to electronic problems. Now it's out of warranty
and it's not working again! This is a first for this problem; it is stuck in the drain cycle; even with the door open. As soon as I push start it (the drain cycle) starts. I have reset using the buttons on the door panel and even cut power to the machine and left set for 30 minutes; just to see if it would somehow magically reset itself. Nothing works. Can someone come up with a solution? Thanks
Related Models
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E REF - SXS/I&W
General Electric SIG140060B SIGNATURE REFRIGERATOR
General Electric SIG1480A66WH DISHWASHER
General Electric SIG1482A68BA DISHWASHER
General Electric SIG60100T0WG SIGNATURE WASHER
General Electric SIG7010ET0WG SIGNATURE ELECTRIC DRYER
General Electric SIG7010ET1WG Electric dryer
Admiral SILVER22 REF - SXS/I&W
Admiral SILVER24 REF - SXS/I&W
Maytag SK525-2W REF - SXS
Maytag SK535-2 REF - SXS/I&W
Gaggenau SK590-2 REF - BOTTOM MOUNTS
Hardwick SKG4622MGA639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG4622MGW639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611A540R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611W540R RANGE-F/S CONT CLEAN GAS
Amana SKI22F REF - SXS/I&W
Amana SKI22F-A REF - SXS/I&W
Amana SKI22F-C REF - SXS/I&W
Amana SKI22F-G REF - SXS/I&W
Amana SKI22FL REF - SXS/I&W
Hardwick SKJ7141819DE WALLOVEN- CONT CLEAN GAS
Maytag SL10AN-A01 STACKED LAUNDRY- ELE
Maytag SL10AN-A02 STACKED LAUNDRY- ELE
Maytag SL10AN-A03 STACKED LAUNDRY- ELE
Maytag SL11AA STACKED LAUNDRY- ELE
Maytag SL11AN STACKED LAUNDRY- ELE
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F REF - SXS/I&W
Amana SL22F-A REF - SXS/I&W
Amana SL22F-C REF - SXS/I&W
Amana SL22F-G REF - SXS/I&W
Amana SL22F-L REF - SXS/I&W
Amana SL22G REF - SXS/I&W
Amana SL22GL REF - SXS/I&W
Amana SL22JB REF - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG REF - SXS/I&W
Amana SL22MBL REF - SXS/I&W
Amana SL22MBW REF - SXS/I&W
Amana SL25G REF - SXS/I&W
Amana SL25GL REF - SXS/I&W
Amana SL25H REF - SXS/I&W
Amana SL25J REF - SXS/I&W
Amana SL25J Ref - SXS/I&W
Amana SL25M2L REF - SXS/I&W
Amana SL25M2W REF - SXS/I&W
Amana SL25MG REF - SXS/I&W
Amana SL25ML REF - SXS/I&W
Amana SL25MW REF - SXS/I&W
Amana SLD22JB REF - SXS/I&W
Amana SLD22MB2L REF - SXS/I&W
Amana SLD22MB2W REF - SXS/I&W
Amana SLD22MBG REF - SXS/I&W
Amana SLD22MBL REF - SXS/I&W
Amana SLD22MBW REF - SXS/I&W
Amana SLD25J REF - SXS/I&W
Amana SLD25JB REF - SXS/I&W
Amana SLD25JP REF - SXS/I&W
Amana SLD25M2G REF - SXS/I&W
Amana SLD25M2L REF - SXS/I&W
Amana SLD25M2W REF - SXS/I&W
Amana SLD25MB2L REF - SXS/I&W
Amana SLD25MB2W REF - SXS/I&W
Amana SLD25MBG REF - SXS/I&W
Amana SLD25MBL REF - SXS/I&W
Amana SLD25MBW REF - SXS/I&W
Amana SLD25MG REF - SXS/I&W
  #2 (permalink)
Old 03-12-2010, 08:58 AM
Junior Member
msmith50 is on a distinguished road
Default Bosch stuck in drain cycle
My dishwasher is doing exact same thing.Drain cycle runs even with door open.I have had no problems with mine unit until now
  #3 (permalink)
Old 04-21-2012, 04:48 AM
Junior Member
punitenshu is on a distinguished road
Default
This might sound like a pretty bad suggestion, but it worked for us when we had this problem and is worth a shot if you're about to blow money on repairs or waste a bunch of time taking it apart.
1. Fill a pot with a 1-2 gallons of water.
2. Dump it into the bottom of the dishwasher.
3. Close door.
4. Turn on.
Our drain was running constantly upon starting a cycle (and would run with the door open, etc.) and we'd heard that there's a part that can get stuck in the "up" position and figured, "Hey maybe if the dishwasher actually has some water to drain, it might pull the stuck part back to the "down" position.
...and despite the simplicity the dishwasher's been working without any problems for 2 months now. (04/2012)
  #4 (permalink)
Old 06-20-2013, 09:54 AM
Junior Member
Nosoup4u is on a distinguished road
Default Bosch stuck in drain cycle even with door open
This reply is probably too late for toungetwster but may help others. Usually when the machine is stuck in the drain cycle, it has water in the base of the unit. The base is water proof and designed to catch and hold leaks to avoid damaging floors and underlayment. There is a float mechanism in the base and if water in the base lifts the float, the machine drains and continues to drain until the water is removed and the float drops. You might have a leak in the unit somewhere or the sensor that detects the water level in the tub may have stuck overfilling the machine. The water can continue to come in the tub and will flow into the base activating the leak float. You need to pull the machine out of the cabinet while still connected to power and water. Take the left side panel off and determine if you have water in the base. If you do, unplug the dishwasher from power and try to extract the water with a wet vac. Plug the unit in to power and watch it fill and run for a full cycle to determine if you have a leak in a hose or fitting under the machine or if you had a stuck sensor on the fill cycle. Depending on where the water came from, you may be able to tighten the hose that is leaking but you may end up buying a part or two.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch stuck cycle michaelje Dishwasher Repair 4 01-02-2011 06:34 PM
Bosch DW stuck in wash cycle? greway Dishwasher Repair 10 01-02-2011 01:11 PM
Bosch Stuck in Drain Cycle; even with door open toungetwster Washer Repair 0 03-10-2010 06:54 PM
Bosch turns on with door open and cycle is stuck ann_14 Dishwasher Repair 0 08-23-2009 11:00 AM
Bosch stuck in drain cycle 89fxrp Dishwasher Repair 0 05-24-2008 02:36 PM
