Discuss
Frigidaire Timer Stuck - Hi Limit Thermostat
 in
Dishwasher Repair
There are three parts in your dishwasher involved in the heating process. They are: high limit thermostat (#29 on the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Frigidaire Timer Stuck - Hi Limit Thermostat
  #11 (permalink)
Old 03-30-2010, 05:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
There are three parts in your dishwasher involved in the heating process. They are: high limit thermostat (#29 on the diagram, page 6), heating element and control board. You have to have an Ohmmeter to check the thermostat and heating element for continuity.
Remove the toe panel and try to pinpoint the noise.
- The high limit thermostat Part number: AP2109201
- The heating element Part number: AP4424048
- The control board Part number: AP3214958
Here is the Tech sheet.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #12 (permalink)
Old 03-30-2010, 08:25 PM
Junior Member
carledlund is on a distinguished road
Default
i had narrowed it down to the thermostat. i was wondering if the burnt tip on the spade was okay to re-use. everything is hunky dory there. the question i now have is the drain pump. its loud- making this humming/churning/cranking noise. i hear it when i immediately start a cycle and periodically throughout the whole washing process. i put a new one in and its better but still louder than i expected. is this normal or do i need to further into the lines somewhere to look for the problem? thanks for all your help- ive learned more about dishwashers in the past few days than i ever though i would need to know!!!
  #13 (permalink)
Old 04-01-2010, 08:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You may want to check the drain hose for a floating foreign object inside. Otherwise I do not see what can cause an excessive noise, especially with the new pump.
__________________
  #14 (permalink)
Old 05-29-2010, 09:19 AM
Junior Member
Tigermoth is on a distinguished road
Default
I have exactly the same symptoms as described earlier in this post by Maddog8212.
My dishwasher is a Fridgidair Ultraquiet111 (FDB750RCC0)
I have copied the original post below.
Is the "High temp sensor" referred to by Maddog the same thing as the thermostat?
What is the part number?
Where is it located, underneath the tub?
Can it be replaced with the dishwasher in situ?
Best regards
Tigermoth
Gene,
Model number first few characters are rubbed out.
remaining numbers are B750RCC1.
Use and Care Manual are for Frigidaire dishwasher 200. 500. 700, 800 series, P/N 154466101 (0405) from 2003.
original post
Need some double check on a planned repair, please.
I have a dishwasher with failed repair by a service company. Symptom was the timer would not advance past 7 o'clock or 10 o'clock on high temp wash or rinse setting. Serviceman replaced the (1) timer and (2) thermostats to no positive effect, just $200+ bill. I got the tech manual, and saw the likely culprit was the high temp sensor.
  #15 (permalink)
Old 06-14-2010, 01:12 PM
Junior Member
kglaub is on a distinguished road
Default Same problem - hi limit sensor part #?
I am having the same problem where the timer works when the dishwasher settings are on cold, but the timer sticks when the heat settings are on. Does anyone know what the part # is for the hi limit sensor and how to install it?
  #16 (permalink)
Old 07-31-2010, 08:37 AM
Junior Member
jwiseman114 is on a distinguished road
Default
I have the same exact problem as what you described. I replaced the timer and was about to look into replacing the thermostat when I found your post. I was hoping that you might be able to give me the part number for the high temperature sensor. I'm not sure how to find it.
Thank you
John
  #17 (permalink)
Old 07-31-2010, 11:36 AM
Junior Member
Default No luck here either
I have not had any luck finding the right part number. I spoke to a local parts distributor and they said there is two hi limit thermostats; each about $25. I have not yet bought them and tried to replace it. Sorry I couldn't help, but if I find a solution I will let you know. Please do the same for me.
kglaub
  #18 (permalink)
Old 07-31-2010, 09:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
jwiseman114 and kglaub,
What are the model numbers of your dishwashers?
__________________
  #19 (permalink)
Old 08-01-2010, 05:24 AM
Junior Member
Default Model #
Frigidaire model #FDB700BFCO
kglaub
  #20 (permalink)
Old 08-01-2010, 08:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
kglaub
The high limit thermostat is located under the dishwasher on the left side and is shown as #29 on the diagram. You have to check it for continuity prior to order it because the problem can be a bad heating element too. It has to be checked for continuity as well.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FDB700BFC0 Frigidaire/dishwasher | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Hi-Limit Thermostat wrk24wheel Dryer Repair 3 03-05-2010 03:11 PM
Thermal Cutoff vs Hi Limit Thermostat vs both Ingots Dryer Repair 4 11-25-2009 09:35 AM
Connecting hi-limit thermostat to new heating coil daleser Dryer Repair 0 09-16-2009 09:57 AM
how do I test the high limit thermostat naudnice Oven Repair (including Ranges and Cooktops) 1 12-20-2008 11:45 AM
Limit Thermostat Doug J Dryer Repair 1 12-05-2008 08:36 PM
